Mitsubishi WS-55909 55" Rear Projection Television Logo
Posted on Oct 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DM board I am having issues with the DM board and need to either replace it or the caps could you send me the service maneul and a picture of the board. continuest flashing green light, tried every tip in the manuel
Sonny Berry
Level 3:
  • Mitsubishi Master 8,617 Answers
  • Posted on Oct 14, 2008
Sonny Berry
Mitsubishi Master
Level 3:
Answers
8617
Questions
Helped
1723078
Points
23750
They have the repair kits for the mitsubishi DM boards at the following link, which contains the replacement capacitors and the CD with step by step instructions.
http://servicemanuals.vstore.ca/
2answers
We have a rear projection Mitsubishi TV, Model # WS-55511.We had a power outage last night and when the power came on this morning, we cannot get the TV 'ON'.There is however the TIMER light on the...
Thats a very common problem caused by weak caps on the DM board when power is lost they drain and then cannot recharge when the power is restored the WS55511 DM repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the caps and the cd with instructions.
I have a Misubishi DLP wd 52825. The timer light keeps blinking and I have no picture or sound. I cannot turn the power on. How can this be repaired? Or what is wrong with it? I have unplugged the TV for...
Most likely the issue is bad capacitors. You need to check for bad 1000uf 16v caps on the dm board and the fmt board. Be sure to checked surface mount fuses on DM and FMT board after you replace the capacitors.
Not to easy of a job due to how much dis-assembly needs to be done. Instructions can be found online on how to do this.
Blinking light with no picture or sound
If you have a green blinking light,
Most likely issue is with bad capacitors on the DM an FMT boards.
1) Look for bad 1000uf 16v caps on the dm board and the fmt board.
2) checked surface mount fuses (small white boxes) on DM and FMT board
Look carefully for other bad capacitors in the general area.
Start here and let me know the results.
Note, there is a lot of disassembly to get to these boards. Not a fun project.
Ws-55511 DM 5volts draged down blinking led
Did you check the caps on the DM board? They usually go bad after a period of time. Remove the DM board and the metallic cover and there should be 4 to 7 capacitors (There are different revisions of the DM board). Check these caps also, replace if needed.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
2answers
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
WS-65513 DM board caps replaced but green light continues
If I remember correctly, there are more than 4 caps on the DM board that need replacing.
Mitsubishi WS 55809 Rear projection TV
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Please send capacitor replacement info
know problem of bad caps.
replace DM
Picture of bad caps
3answers
WD-52525
You will need the service manual to do this repair. I happen to have it, as this site was suppose to put in the pictures and things to explain that a lot of TV sets are still using this DM board, but they are building them differently. Just follow the directions in the service manual on how to remove the DM board and then follow the directions in the article on repairing the DM board. I will need your e-mail address to forward this service manual to you. Good Luck
1helpful
8answers
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
