Tape keeps ejecting - panasonic nvfj620
Is it only the Head cleaning cassette which keeps getting ejected, or is it happening with every tape you insert?
Was the Head Cleaning Tape a little tight in the Cassette compartment? Did you have to put some pressure to push it in or did it come out with difficulty? From your symptoms, it looks like there is a gear timing problem with the cassette loading compartment gears. It could also be due to some obstruction inside. try shaking the VCR, and if you are hearing some noise, Open cover and check for foreign objects.
I don't think I even want to try opening it up myself. I guess I will just have to take it in somewhere and have it done.
it will have to be opened up to determine the exact problem , might be a sensor , might be a belt, do you have and knowledge and or tools?
