Had to format the computer that had our Sharp AR-M160 copier on it, and now I cannot reload the sharpdesk 3.3 software because we do not have the original manuals that had the serial key for the software. how can we get this, and is there just a quick set of numbers that will let us install the software. I saw in another post online that using all 1 (one's) would work, or all 8 (1's) in the last box, but neither of theses tricks worked for us.
SOURCE: Force NST icon to show up in the tray.
During installation you should of had the choice to add to start up if not all you need to do is copy the NST to the start up folder. As far as "forcing" ip updates not available. You really need to have static IPs for your pcs. If static not available then you should set up the scan to e-mail option.
SOURCE: H4 error code
Image Quility can be the "AE" botton in between the lighter and darker adjustment or it can be the text/photo botton. I'm not 100% sure which???? Try both to lock it in....
SOURCE: I have a sharp AR-M205 using sharpdesk 2.7 and can
When you installed the button manager you should be able to go in and change the SC descriptions ex. SC1, SC2 - SC6. When you use the sharp desk to scan you are operating in a pull scan but when you use the SC programs you are using the push scan mode. You can change the SC mode when you put the copier into scan mode.
SOURCE: One of our Sharpdesk users is unable to view her
You can also right click on the file and left click on "open with" and then select choose program. In the list of programs choose Adobe reader and then at the bottom of the window put a check mark next to "always use the selected program to open this kind of file"
This should take care of the issue
SOURCE: I have a Sharp AR-N275 and would like to add a
go to your internet browser and type the IP address of the copier into the address bar not the search bar the browser should open the web page for the copier if you need help from there then post to me
