SOURCE: 2 pc connected but wont allow both on internet at once
Set up both pc's with dhcp. To do this, right click (My Network Places) in the start menu and choose properties. Right click your network connection and again choose properties. Click Internet Protocol (TCP/IP) and then select properties. Choose (Obtain an IP Address Automatically). Then (OK) and again (OK). Do this on both pc's.
SOURCE: WAN
WAN s not for your use now. dont dig with it bro..
tel me one thing.. what kind of connection you have? does the modem stores the password or you type the pass each time manually to connect to internet
SOURCE: Open Port 81 on Netgear Switch
Actually you need to open the port on the cable modem / router. Switches just pass the packets along.
SOURCE: WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
SOURCE: got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
