Proton SRC-2010 LCD Touchscreen Remote Control Logo
A
Anonymous Posted on Jan 13, 2012
Emprex tv remote control codes for direct tv - Proton SRC-2010 LCD Touchscreen Remote Control
1 Related Answer
Anonymous
  • Posted on Feb 03, 2010
SOURCE: REMOTE CONTROL CODES FOR EMPREX TV
Emprex uses the Memorex codes. They are 1002, 1004, 1005, 1010
I have an emprex tv and cannot program my comcast remote to it. No code is working
0324 0378 0421 0456 0460 0604. Check these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Emprex tv LXA 42A100B model LT 42409
Check the infrared emission from the remote control first, before confirming, the remote sensor inside the TV is faulty. If you wish to get some details about how to check a remote control, check the site linked here. If remote control is found OK, then only move to replace the infrared sensor inside the TV. The failure rate of infrared sensor is very rare case. http://electronicshelponline.blogspot.com/ If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Need code for emprex tv
1195 1145 1120
1225 1012 1231
1002 1317 1032
These are the codes to check. If you wish to get more, check these links. http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
How to activate the remote to an emprex tv
you must read your owner manual download from
www.retrevo.com
or download your code from
www.remotecodelist.com
God bless you
Needed a code for a universal remore control for emprex tv
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
1helpful
I need the Emprex TV remote control code to program into my Dish Network remote control. Dish Network does not have this code.
We would be happy to help you with that. Currently the onlycode we have that will allow you to control your Emprex TV is 597. If this codedoes not work we would recommend doing a power scan.
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer.
Phillip Chang
DISH Network Customer Service Representative
1helpful
2answers
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
Emprex HD 3202 control panel not operating
My first thought then is that the main board may have capacitor damage that will affect the boards ability to "understand" the control signals, if you can I would have the tv looked at at a service center for damaged boards and components, might be an easy fix but might not be (new boards), The lcd panel is good that can net you several hundred dollars at a min.
peope break them all the time and a simple change out is worth several hundred dollars, vs a new tv
10helpful
2answers
Top Proton Televison & Video Experts
matt martin
matt martin
Bob Kirkwood
Larry
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
