Question about Dell Dimension 3000 PC Desktop
I have a Dell Demision 3000 Series, it shows black screen when I try to reboot it displays adminstrator password required, I had this computer so long I dont know where to get the password.
It shows a black screen when I try to reboot it buy pressing F12 it request adminstrator password required, I had this computer so long I dont know where to get the password. When I press F2 it shows 8 options to choose from, when I choose any it request I press F1 or F2 and when I do this I'm back to password again. What can I do that will not cost me anything.
    New Friend:
First unplug all power from your computer. Next open the side panel of the desktop. Inside the computer you will see the motherboard. locate the battery ( round flat like a quarter size, silver color). Carefully ( very carefully) remove it. Wait 10 seconds and reinstalled it. This will reset all your cmos or bios setting to factory setting including deleting your password.
Posted on Sep 10, 2017
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 24 Answers
SOURCE: restoring computer factory settings
another suggestion is boot the system from your OS disk, if you have one, and repair or reinstall OS. Reinstall should not cause you to loose any files.
Posted on Jan 03, 2009
torresfvr
Fernando Torres
  • 69 Answers
SOURCE: Disc failure 0 press F1 to continue
He has accessed the bios and change the boot setting devices by enabling the floppy drive which you do not have.
Go Bios (F1 or F2) on first screen. and select load default setting
Also go to Boot Options and make sure 1st boot is the HDD not FDD or removable disk
Also in any menu mention of Floppy Disk make sure it is set to not installed or disabled.
keep me posted
Posted on May 21, 2009
k24674
  • 8081 Answers
SOURCE: Dell GX260 wont boot a Linux Live Cd
Could the boot record on the CD be damaged? Try it on another computer to find out. As the live CD loads the program in RAM, you need to see if your system has enough RAM (It depends on the minimum amount of RAM required to run the particular Linux Distribution)
By the way if you are interested in installing Linux inside Windows XP without creating a separate partition, Ubuntu offers this.
Hope it helps.
Posted on Aug 30, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: I am trying to reinstall
Check the Date and Time setting, if these are wrong you will get the Strike F1 and F2 message.
OR
The BIOS battery is flat and it won't save the BIOS settings. In this case, replace the BIOS battery and configure the BIOS again.
Posted on Oct 15, 2010
In my Dell 15 3000 series I was doing some important work that time suddenly the display gone black but laptop is ON only. What will be the reason can one tell me please
Posted by Pradeep Guru on Jul 05, 2018
Is your PC 2 years old or 20 ?
dell reUsed the model names, (sad no?)
the service tag information is 10x more better, post that. ok?
the screen is 100% black , never shows text at all??
fan is dead.? (power on and listen close)
remove the large battery pack, run on AC pack only.
runs now? bingo.
fans still dead. do the long reset here.
Dell 15 3000 2016 or the
Inspiron 15 3000? (1998)
I guess is 2 years old max (2016 shows in the guide at dell.com)
not the Dell 3000 from 1998?
3000 series, try tell the full model number and not just the series #
ok? be exact. on model, ok?
if the fan is dead inside say so and first.
that means there is no power to the PC (inside)
the fan must blow air. and speed up if too hot (inside)
if the fan does work.
and battery big out and AC pack good
you can connect the HDMI jack here to the TV and see if you get text or other errors are windows logon screens.
left side HDMI and matching cable. 2016 and newer 3000
hdmi-oyuevl04yzmzelvn3qorlmkh-2-0.jpg if your PC is 1998 (there is VGA JACK TO USE)
the battery large is no good, and shorted out and must be removed.
the tiny RTC coin cell this old is 100% hopeless, this old.
replace this next.
the test the HDD using a linux boot CD.
test the Laptop with Lunux demo CD. see if the PC is ok
then reload what ever OS you like, (ask)
Jul 05, 2018 | Dell Computers & Internet
Cannot get into set up to check bios
  • 1
    Turn on your computer. If your computer is already on then reboot it. You need to see the initial display screen to get into the BIOS.
  • 2
    Press the "F2" key when you see the initial screen displaying the BIOS provider information. If using the Optiplex and Dimension models, press the "DEL" key instead of the "F2" key.
  • 3
    Enter password if required. When finished in the BIOS be sure to save your changes. For changes to take place you must reboot the computer.
    Read more: How to Get to BIOS on a Dell Computer ' eHow.com http://www.ehow.com/how_4745021_bios-dell-computer.html#ixzz1VDktcHYE
  • If the bios is password protected you will have to dump the bios batter first, then reconfigure the bois.
    Aug 16, 2011 | Dell Dimension 3100 PC Desktop
    Dell laptop ... inspiron 6400 System/adminstrator password
    I believed this can be resolve by clean the cmos battery. you need to remove the cmos batery from the laptop then power it on then immediately turn it off. then put the battery back to the laptop then power it on keep tapping on f2 to enter setup. please follow the instructions from the link to remove the cmos battery http://tinyurl.com/yb3mhyg
    Mar 29, 2010 | Dell Inspiron 6400 Notebook
    I can't boot my computer cause i forgot my password
    I suggest you try hard to remember your windows password, otherwise you have to reset it or reinstall Windows. I do not recommend you to reinstall Windows, which may lead a data loss. So if you really can not remember the password, try Windows Password Seeker http://www.passwordseeker.com
    Oct 06, 2009 | Dell Dimension 2400 PC Desktop
    Dell dimension 3000. Just Black Screen no Windows XP.
    From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
    Jul 06, 2009 | Dell Dimension 3000 PC Desktop
    Password
    Try pressing "ok" if you did not set a password. Otherwise a password must be set on the computer like the one at the log on screen.
    Jun 23, 2009 | Dell Dimension 3000 PC Desktop
    Blank Monitor
    I have the same system and card. The problem is the system is trying to run two monitors at once. Use Windows safe mode (F8 during boot) to uninstall any Pny drivers you may have put on. Reboot. Install the pny drivers again. Before rebooting, use the device manager to look at the display drivers. There should be two, an Intel one, and the pny Nvidia one. Disable the intel driver and reboot. Worked for me. Youmay also want to upgrade the power supply. The 3000 has a 225W and the 8400 card wants at least 300W.
    Mar 28, 2009 | Computers & Internet
    Dell Dimension 3000 PC Desktop Logo
    299 people viewed this question
    Ekse
    Alun Cox
    Thomas F. Schneider
