Sony cd rw crx 850e reads dvd fine but it will not read cd r and wont let me burn cd r it all worked fine a week ago then i was going to burn a cd for music to be played in a cd rom player as ive done in the past it stoped midway threw the burn ruined the blank disk and will now not read any type of cd r pre burned or blank to burn
SOURCE: Sony DVD RW AW-Q170A Burning Problem
1. pl confirm ur drive as as sony as AW-Q170A
2. Download both file necflash_wingui.zip and 113bt_rpc1.zip
3. If ur not sure about drive being master or slave turn all the IDE to PIO mode. Pl remember flashing will not be possible if in other mode.
4. Unzip the zip file
5. Run necflash dump the firmweare file at safe location and flash the bin file with 113Bt_prc.bin.
6. Reboot in safe mode. Restore IDE to original mode.
7. Reboot and start normally. Bingo prob is solved
SOURCE: Wont Read OR Burn DVD's
Hi There that is a hardware failure inside the unit there are two different lasers in the one head one for cd and one for dvd it sound like the dv d head has failed if the unit is new or under warrenty its time to speak to your supplier or if not bite the bullet and invest in anew unit
sorry for the bad news
Regards AL "Alstech"
SOURCE: why my [sony cd rw dvd rom] will not detect a blank dvd disk
my computer CD-R broke but i have DVD-R both how can i burn mp3 disk on the DVD-Rom driver it wont work it says please insert black cd but there is blank disk in it how can i burn cd on the DVD-R drive.
SOURCE: Sony DRU510A, will burn CD fine, but not DVD, will play DVD
Same thing is happening to me. Does anyone know of a solution to this problem?
Read/Write Speed CD-R Write:
4X, 8X, 12X, 16X CLV
24X ~ 40X P-CAV
52X CAV (turbo mode) max.
CD-RW Write:
4X, 8X, 10X, 12X CLV
16X ~ 24X CAV max.
CD Read:
52X max.
Buffer Memory
2 MB
Random Access Time
100 ms.
Interface
ATAPI/EIDE
Sustained Transfer Rate (CD-R/RW Discs)
600 kB/s (4X CD-R/RW read/write)
1,200 kB/s (8X CD-R/RW read/write)
1,800 kB/s (12X CD-R/RW read/write)
7,800 kB/s (52X CD-R/RW read/write)
Media and Modes Supported
CD-R, CD-RW,
CD-ROM (Mode 1 & Mode 2),
CD-ROM XA (form 1 & form 2),
CD Audio,
Video CD,
CD Extra,
Multi-Session,
Packet Writing
Burst Transfer Rate
PIO Mode 4: 16.7 MB/s,
Ultra DMA Mode 2: 33.3 MB/s.
no you will need dvd rw to burn dvd's
hope it helps
