Well i have the same the proble with my sylvania plaza t.v however when i plugg it in into the socket the red light blinks then the green light comes on but then it just turns off completley...and the red light is still on ? is there a way to fix this problem or is the t.v permently broken??
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
If other electronics are too close to a TV this is a common problem. Try moving the 2 items at least 2 foot away and see if that helps.
You may not want to leave them there, but at least you will know if that's the problem!
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
