Simple enough prob - go to any local mower repair shop or hardware store and buy the small bottles that you mix with 1 gal of gas - all 2 cycle engines can use it - it makes life so much easier-
You could be running the oil gas mixture with not enough oil. The high speed jet could be running the engine lean. The cooling air thru the engine could be blocked by debris/leafs.
One question mark is sufficient. Please refer to your owners/service manual for part identification.
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
You'll need to contact your local authorized service center for assistance.
Check for spark in the new spark plug, if you have spark clean the carb fully and try again. make sure you have correct mix of gas to oil and it is not old use fresh gas oil mixture. Good luck pal.
the l is for idle and the h is for top end but thats not ur problem it sounds like ur carb is clogged there is a screen inside of the carb the fuel gets crystalized and blocks off some and sometimes all of the fuel ill bet thats the problembut u can try the adjustments first give the unit full throttle and turn the h adjustment screw in and or out till it sounds great and at full power if that dont work then do the screen in the carb
No place on the blower is there a ratio for mix. l
