Intex ; syz1
You will need to open up your network connections Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled hope this helps click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
SOURCE: DRIVER OF RTL8139d - 83326S1(intex)
Dear mykew87
You can Download the Driver on intex Technologies
Website Link:
http://www.intextechnologies.com/webpages/download-driver.aspx
Driver Link:
ftp://122.180.13.163/INTEX%20DRIVER/LAN%20CARD%20IT-584%20WinXP,Vista/WINXP.zip
Thanks & Regards
Lokesh Kumar
http://freeallsoftwares.com/
