Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Posted on Oct 11, 2008
Black only on photo-paper
If i take normal paper (80g), no black color is printed. If I take photo paper, everything is fine. Need help!
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Oct 11, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
2476
Points
17
Print out a demo sheet. Press copy and photo at the same time. If the black isn't printing on this demo sheet, (the eyes on the two kids at the top are all white), you need a new printhead. contact kodak tech support. 18004216699. Option 1
2answers
Printer is not printing the black colour when i load the paper from the rear slot...
Hi
try printing a "Nozzle check" to confirm that both your black cartridges are working ok. One cartridge - the smaller (photo) one is used for printing photos on glossy paper. The second - bigger cartridge is used on plain (copy) paper. Sounds to me like your smaller (photo) black cartridge is not working. It's either empty or may need "Cleaning" or "Deep cleaning". In case you don't know...Nozzle check, Cleaning etc utilities can be found on "Maintenance" page in "Printer properties".
good luck
Lumir
www.inkbank.com.au
3helpful
2answers
Why does the printer use one black cartridge and not the other? Is there some way of instructing it to use the left hand one too?
the pixma printers use the large black tank in most modes like text and standard (default) or fast photo printing .. thats most economical when you are using just plain paper .... it will switch to the small black tank only if you select "High" quality mode .. that black matches the nature of the color inks much better and results in really good color pictures if you are using Gloss or Matt high quality photo paper .. you can select the quality level by the following ... when you start to print, a window comes up where you can select which printer you want ... at the right of this window is "preferences" .. click that .. now select the type of paper and "High" quality mode .... now the printer will slow down but will provide really nice results and it will use the small tank black ink instead of the large tank ....the small tank is only used for "high" quality photo prints which is only needed for high quality photo paper .. if you havent tried that yet you might want to get some glossy photo paper (either Canons or Costco has great stuff if you want a lot, like 150 sheets) but most glossy paper will work except colors might need tweeking for some ... print a nice photo in the high quality mode and you should be really impressed .. and you will be using your small black ink tank .. you might want to make the first few pictures small (2x3 inch) untill you are sure everything is the way you want it .. i usually print in the top left corner first .. then reinsert the same paper and try again right next to that .. i do that until i get the colors perfect .. then i print big .. 5x7 or even 8x10 on a new sheet... the high quality mode can be selected for just plain paper and it will use the special black ink but it doesnt result in a better picture .. so no point in doing that unless you want to experiment .. if you never print high quality photos then you will never use the small tank black ink .. it will still be used up eventually because of normal head cleaning the machine does automatically .. ...
grey scaling does not select the special ink unless you select "High" for the quality setting .. then yes you can print using that small tank black ..again it will buy you a lot if you are using High quality photo paper ... almost nothing for plain paper but at least it will allow you to use that ink .. ..
Black re-mfg for psc 1610 prints unreadable
your black print cartridges has been dried, these need to replace.
2helpful
Black text printing not using large cartridge
Change your setting to plain paper and normal quality.
This printer uses the small black for photos and high qau;ity papers.
Do this and you should be good to go.
1helpful
Canon Pixma ip1500 is printing but very wierdly. random lines will not show up in black. If i change the color everything is fine but black will skip lines and such. Please help! Can't turn in job...
Your printhead is plugged and needs cleaning. If you remove the inks and then the printhead, you can wet and fold a paper towel and just dab the printhead gently on the wet towel. When you see a solid black line on the paper towel your printing should be improved.
Photo printing quality is poor
dont mix colored with photo. we had the same problem and i bought black and color and it worked fine after that
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
1helpful
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
Black ink on glossy paper looks like leopard spots
printer need head cleaning , after cleaning check nozzle , if solid color appear w/out space on black color it means good and clean nozzle.
2answers
Trouble printing to photo paper
The paper you print on is not relevant. What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black. On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended. So what can you do? Move away from black and go for a tint such as sepia.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
