CMOS IS LOCKDOWN FORGOT PASSWORD WOULD LIKE TO RESET OR REMOVEPASSWORD, WHERE IS THE CMOS BATTERY FOR password reset sony vaio VGNFJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
I have opened the laptob but icant find the CMOS battery.
can you help where i find it on mother board?
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
sony vaio vgn-fj290p
you can get the Sony Master Password here:http://sony-support-on-bios-password.bio...
as long as your sony laptop display: ( system disable ) or ( Enter Onetime password key ) I have unlocked many laptops with them and it has always worked for me !
