I haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks Mahesh Shinde 9922986565
I haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
I haver Brother Laserjet DCP 7055 printer and now it sowing that error and replace toner
https://www.youtube.com/watch?v=XnlhQISW... try this ; I hope you can solve it.
Users of brother printer need to know details that how to fix Brother printer toner error so just make a call on Brother Printer customer service 1-888-587-9269 anytime 247 and experts are there to help you 247. Call on Brother printer Support 1-888-587-9269 anytime and sort all issues of Brother printer with the help of technicians.
http://www.allsupportno.com/how-to-fix-brother-printer-toner-error
SOURCE: how can i refill dcp 7030 cartridge?
Leading-in картриджа type 215 (DT36BLK - NRG) for printer Ricoh serieses AP2600/2610; NRG P7026/P7026n/7132n; MB326
Taken for example картридж is used by client since 2007, and this was his(its) last leading-in. The Main defect for these картриджей is small lifetime drum. But, my opinion - 60 thous. pages, all are enough for his(its) okupaemosti.
For beginning we remove the bunker of the collection of the perfected toner. For this neatly, small screwdriver with flat blade, wring out by turns, two ушка with left and with right sides and take out the bunker. Careful his(its) вытряхиваем, отстукиваем become firmly packed toner. We Process the vacuum cleaner and put on mesto.
The Note: bunker very and more capacious, but better not to be lazy and clean under each zapravke.
remove the lateral lids, which connect two halfs картриджа, and analyse him(it) on two chasti.
Inspektiruem develor part Ща cartridge with drum. The Roller of the charge clean, wash. Rakelinyy knife remove, check and put on place. If drum not powerfully worn-out and wholly пригоден for the further work, that polishes, sprinkle the talc and put on place. If there is damages, not compatible with life ORSA, that here variant two:
1. to search for than change;
2. to sell the client new kartridzh.
On this first part is postponed in storonu.
With half картриджа, where are found магвал and bunker of the toner to trouble more. Since itself картридж двухкомпонентный, there is two directions or algorithm of the work with тонерной half kartridzha.
The First variant: cartridge new, develope is enough, toner on buttom - simply add tonera.
The Second variant: cartridge passed already one zapravku.
Then do so: we take out the fixative wedge an anything numbered six шнека presenting the toner, by means of узкогубцев remove the greater anything numbered six with axis presenting the toner, remove the transmission anything numbered six (refer to photo
We Disconnect the block (or node or девелопмент юнит - to whom what likes) of the magnetic gross, applicable small screwdriver with narrow flat blade, having wrung out two защQлки on bokam.
We Remove the block an магвала, small bunker, with transparent window and there is receptacle девелопера. Vykinuti his(its) it is impossible, but use impossible. His(its) simply disconnect, as a matter of convenience further peelings of the block from the remainder of the toner and developera.
The Magnetic gross and whole node carefully вычищается from toner by means of vacuum cleaner. The remainder tonera. delete From bunker of the toner
All, begin предзаправочную sborku.
We Install on place small bunker from beneath девелопера, insert on landing places node магвала. The Trouble for 5-10 minutes minimum. Then we take the lateral gap out of polyethylene and fall asleep through it toner.
We Collect two parts картриджа together. We Bolt the lateral lids. We Put avtograf.
The Toner was used HP LJ 2100 from Mitsubishi, adjustment changed on most printer to density of the scene before 2.
In view of неидеального of the correspondence to of the toner to requirements TD sensor it is necessary to get ready to that that to fuel картридж come more often, but the remainder of the toner in bunker will much more be in comparison with original. In the same way warn about premature mortality anything numbered six drive фотобарабана in most printer Gear OPC ***'y. Occurs because of rickety шестерQнки on most фотобарабане, but prime cause is a compatible toner, or, вернее,
SOURCE: Brother Toner Refills
Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
www.tonerrefillstore.com
www.lasertekservices.com
They also have great customer service. I hope this helps!
SOURCE: After i refilled the toner
When you refill the toner cartridge you have to reset the chip on the toner, otherwise the printer still sees it as empty.
SOURCE: Need service manuals
You can access all of Brother's printer manuals online at their website in .pdf for free. Just go to http://www.brother-usa.com/manuals/default.aspx?PGID=5&R3ModelID=DCP165c and find your printers; you don't even have to download them.
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
