I have tried unplugging it and holding in the power button but nothing works. It just keeps flashing the "POWER LOCKED" message on the screen.
SOURCE: how do you unlock the power button?
press the down and the power botton both at the same time end hold it for 20 second then release that´s all
SOURCE: On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
SOURCE: buttons locked on AOC 24'
you need to run a channel scan useing your remote run set up like when you first bought the unit
On the tv press and hold the + and - volume control buttons and the buttons should unlock.
SOURCE: My son bought an AOC LCD TV (model L24H898) last
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV.
2. Using other hand, press the power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and select.
5. Power off and re-boot the computer
6. Run channel auto-scan to regain the picture.
