Hello. I received a RadioShack Universal Remote control to use with a JVC TV. I would like to know step-by-step how to program the remote control so it will change the channels with the Cable TV plugged into it.
Thank you
Programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
I need the Sony tv code for my remote Radioshack control 15-2147.
I cannot get my menu button to go to channel programming all i get is sleep timer on my magnavox tv with my radio shack remote
I need the code for philplis tv please
Just press the tv icon and then press setup hold it till the llight blink twice then enter the tv code
What about an RCA tv??? anyone have the codes?
i need the code for sony tv whit this remote control thanks.
hola tengo un problema con mi control no se como programar un tv de marca daewo
I have this remote and need to know the codes of a sylvanian tv
Need the codes for an RCA, to program into the Univeral Remote 15-2147.
