Nikon D300 Digital Camera Logo
Ed Kaye Posted on Jan 11, 2012
What does error -50 stands for?
LEXAR CF card. it shows trying to download and open AVI files into quicktime? help!
2 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Jun 07, 2008
SOURCE: CONSTANT FLASHING CF LAMP NIKON D300
Am afraid that it is an internal hardware problem. Chances are that the electronic trigger that fires the flash has shorted out and is therefore making the flash work even with the camera off. Since this would involve electronic circuitry and components, use of a DVM and a low wattage soldering iron or even a hot air blower, perhaps your best bet would be to seek the services of a qualified professional. Often even if you can actually open the unit for a look and see of the trigger/flash module, replacement part availability would be a major concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
ARTGIRTNY575
DASEP
  • 96 Answers
  • Posted on Jul 08, 2008
SOURCE: My Nikon Coolpix 2100 Lexar starter memory card has become unreadable
It sounds like your Dazzle is not compatible with the sandisk. Maybe the Sandisk CF UltraII card have a new update software in it.
Artgirlny
My MacBook Pro OS X 10.9.1 won't read my Lexar Professional 800x 8 GB Compact Flash UDMA 7.
You can try using a file recovery software like Bad Copy Pro 4.10.125. It works well for me.
tip
How to recover photos from CF Card?
CF card is widely used by digital camerafor its larger , from about 512MB to 64GB, lower cost as well as fasterspeed, which allows digital camera shoot under special conditions, such asmoving objects. The most popular and trusted brands for CF Cards includingKingston, Ritek Ridata, SanDisk, Transcend, Apacer, Viking, and Lexar.
Reasonsof lost photos
Lost photos in CF cards can be caused bymany reasons: card damage, failure, corrupt, etc. and the following are some typicalphenomena.
1.
Accidently selected "Format" onyour digital camera and erased all the pictures on the CF card.
2.
Keeping take photographs whenthe camera battery is at the end of its life.
3.
When upload images to computer,mistakenly judge the finish of uploading and eject the CF card ahead of time.
4.
Turning off the camera beforethe image is completely written to the CF Card
5.
Receiving an error message like"card not formatted", "card not found" or "no images found"......
How to recover lost photos from CF card?
Before recovery, you should know that yourphotos are not erased actually. It stored on CF card as a file. When you formatthe card or deleted photos from the card, the data on which the images werestored is not deleted. It only allows new pictures to take its place.Therefore, make sure not taking new photographs any more in case that theprevious photos would be overwritten.
Data Recovery program like Card DataRecovery can help you get backpictures from CF Card easily. Download Card Data Recovery and Install it onyour PC. Take out the CF card from digital camera and connect it to your laptopor connect digital camera to PC directly. (If your desktop or laptop has abuilt-in card reader, things will be much easier, if not, you need a cardreader to help you.) Then your CF card appears as a drive letter when you go to"My computer" If you see this, it means Card Data Recovery can access andrecover your pictures. Select "photo" and scan your CF card. The process isquick and all recoverable images will be listed with the same signature. Previewthe photos before recovery and restore what you wanted.
Besides retrieve photos, Card Data Recoveryalso can recover video, music, files, etc. Popular video and audio formats likeMOV, FLV, AVI, WAV, MP3, MP4, MPEG, etc. are available with it.
on Apr 21, 2011 • Computers & Internet
AVI files will not download or show in Windows Explorer
Use a card reader to download to a folder you create on your desktop. You need a player to open the files...I suggest Quicktime. It's a free download from Apple.
2answers
Quicktime
You can try the following,
1) Navigate to library, it will be in your main drive.
2) Remove all files from the QuickTime*.PKG, where "*" is your version number. This tells you that those packages are not installed.
3) Click on the "download Quicktime" link. DO NOT USE THE AUTOMATIC UPDATE UTILITY. Download QuickTimeInstallerX.dmg. Double click this file (probably on your desktop) and then invoke the installer by double clicking QuickTime701.pkg.
4) Restart the computer.
Regards,
Shrey
2helpful
5answers
HI, I've movies on my computer and they don't play
u need to install the codecs for the window media player.....if u donot have den download those from this web site
http://www.soft32.com/download_2592.html
other just download vlc media player...its a very good software n it plays almost all the file extensions....good luck
5answers
I cant watch an avi file on my laptop which is a mac book pro
Yes, you can. Download and install the app VLC from www.videolan.org , open it and use to play the avi video file.
2answers
Error 2048 in QT
I think you should try this program.. I use it myself and I know it plays almost all video files:
http://www.videolan.org/vlc/download-macosx.html
PS: Please rate this solution
Artgirlny
2answers
"card error"
Have you tried formatting these cards in your camera? You will find the setting in the menu as per page 26 of the manual. Also check that the correct card type is set for xD or CF as appropriate. You can download the manual from the link below: http://www.olympusamerica.com/files/EVOLT%20E-500%20Advanced%20Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
2answers
Can't play certain .avi files on quicktime
We do have issues playing .avi files which have been compressed using CODECs that are unavailable for QuickTime in MAC OSX. Here is what you can do... http://www.thexlab.com/faqs/avidivx.html Revert back if this doesn't work.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
