Question about Dewalt DC925 Cordless Drill
Problems with torque clutch in new DeWalt tranmission
I recently replaced the transmissions in 2 DeWalt DC925 hammer drills because the torque clutches were slipping in "drill" mode. Now the torque on both drills is infinite when set on speed 1. When set on speed 2 or 3 the low end torque settings are very high(too high to be useful) and go up higher. I thought the supplier may have given me defective transmissions and got replacements which did the same thing. Then I ordered another transmission from a different supplier and it did the same thing. I checked to make sure the torque adjustment rod on the transmission is going into the hole in the adjustment collar and it does. However I must apply some pressure (as if I am compressing the torque adjustment rod) to get the transmission housing to seat against the motor housing - and this is when the torque color setting is on 1 - which makes me think this if affecting the torque settings.... Am at a loss - HELP!
    Habit-Forming:
    New Friend:
  • 121 Answers
Hi
like most clutches on hummer unit after the assembly has been done you will a way to tighten the spring clutch look for adjustment to make the spring looser and tighten
Posted on Jan 29, 2018
5 Suggested Answers
Anonymous
  • 313 Answers
SOURCE: Dewalt 18V XRP Clutch Slipping
it very economical to repair the drill. replace the transmission.
Posted on May 24, 2008
Anonymous
  • 313 Answers
SOURCE: clutch and speed selector problems
drill needs transmission and switch probably co'z it's loosing the varaible speed.
Posted on May 27, 2008
Anonymous
  • 313 Answers
SOURCE: Dewalt DC925 Clutch Ring Jammed
if your in hurry & away from the service center all you need to do is just loosen the 4 screw that holds the clutch housing & set it # 1 & back to drill mode couple of times. do not remove clutch if your not sure co'z its got tiny needle bearing on front of the transmission.this is just a temporary fix . it may happened again.
Posted on Jul 06, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: chuck has no power dc925 hammer drill
No return it to a Dewalt service center for their Max Repair Rate. They will fix anything including batterys for a set amount, if it is less then you pay less. If not give me the exact model number and I will look into it.
Posted on Mar 18, 2009
Chuck Bamforth
  • 205 Answers
SOURCE: i have an 18v dewalt hammer drill dc925 and cant
It's one of the settings on the clutch ring. Or do you mean it won't turn there?
Posted on Mar 22, 2009
My Dewalt DC925 works well but the torque settings don't seem to be working.when i am drilling screws the drill will just drill until i release the trigger.is this a clutch problem?. Many thanks.
Try to put it on the lowest torque and if it slips when wanted, then add a little more torque and check to make sure it slips. Continue at each torque setting and usually works again at full torque. Usually happens when left on the same torque all the time. This kind of resets it.
May 07, 2015 | Dewalt Drills
I have a DeWalt DC925 type 1 hammer drill,took it apart to repair switch and clean. Four pin bearings fell out,I don't see them on a parts diagram,where do they go ?
You will find them in the transmission, remove the metal cover and they will be located just under it - sounds like it is either the gear posts or the clutch cams on the nose side of the transmission DeWALT DC925 Type 1 Hammer Drill Parts
Mar 23, 2015 | Dewalt DC925 Cordless Drill
Can't engage drill or hammer settings on de walt dc 925 xrp
Try turning the ring to 2 or 3 and run the drill holding the chuck so the clutch slips then try turning it to drill setting. Also try to do it in different speed settings. If not it sounds like a fault in the gear module. It might just be a metal clip just under the clip in side. Undo the 4 screws holding the gearbox onto the housing and carefully remove it, you might see the fault or loads of dirt that needs cleaning. Go to http://www.2helpu.com/world/map.aspx for a drawing.
Jun 01, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Clutch slips reguardless of setting, in both drill and hammer mode. won't drill. is this a transmittion problem?
You can get the part replaced with metal gearing and clutch and that shouldn't happen again, but the cost may not be worth it
Mar 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Drill works fine but wont engage hammer. the torque ring goes from 1 to 21 ok but i cant engage the drill or hammer setting
On my DW988 the ring would go past 21 a couple of clicks to a symbol that looks like a yellow T and that would be hammer mode when I press down to drill.
Nov 18, 2009 | Dewalt DC925 Cordless Drill
I have a dewalt dc925 combi drill the chuck keep slipping and also the setting ring is hard to adjust . What can i do top solve this?
Probably needs a new transmission. They cost about $34 plus shipping. Easy to fix. Just remove the four torx screws from the metal (gray in color) part of the drill. Then pull it apart. The transmission comes in a one piece cassette. Pull out the old transmission, insert the new one, put the front back on and tighten the screws.
Mar 10, 2009 | Dewalt 2 Dc925 18v ½ Hammer Drill /...
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
HAMMER MODE SLIPS OUT
i am guessing the transmission problem not enough tension to the clutch
Aug 11, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
Jun 07, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC925 Cordless Drill Logo
1,315 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
