I am trying to reinstall xp and it starts to and then goes into sleep mode after about 1 minute
SOURCE: laptop will jump from windows start up to start insafe mode
go the back case of your laptop then find and open case of memory then make a clean
SOURCE: my tecra m1 os
place XP CD into your CD Drive that is set to boot first in your Bios.
And reboot, When prompted (usually one of first things) press any key to boot from CD" do that....
once you get to the screen that loads press ENTER to "set up XP now"
Then press F8 for the user agreement
The next page will show your previous installs.
choose yours..
Select "Install a Fresh Copy of XP without repairing"
the next page will show some options with your drives and partitions listed below.
from there you want to select the partition with your current XP install,
Then smash "D" on your keyboard to delete the partition (this is where all data is lost on the drive)!
you will need to press Enter on the next page to confirm.
and another confirmation press L
next you will see your drive press C to create an new partition
next
you can just hit Enter to create partition the full size of your drive.
(suggested) or you can change the size and have multiple partitions.)
once you have created the partition press Enter to install
windows will tell you the drive is not formatted and will offer you
some choices... choose NTFS Quick or Slow ( I use slow on smaller drives and quick on the big ones.)
SOURCE: My Toshiba Satellite L305-S5875 always crashes on a cold boot.
Part of the problem is the hybernate function it causes windows to become unstable and eventually will corrupt the windows files making vista unusuable. I strongly suggest the hybernate mode be disabled and you make a backup recovery disc just in case windows crashes. By following what I have recommended and shut down windows when not in use will make a big difference in stability.
