Question about Kodak EasyShare C143 Digital Camera
What could have cause the over hear on the outer part?
  • sylvesterkar
    sylvesterkar Jan 10, 2012
    the flash is not coming out when u take a photo
  • 10,421 Answers
Please change the flasher setting to auto or always flash
Posted on Feb 13, 2012
Anonymous
SOURCE:
Why my 2010 Venza drive on sometimes while driving it sound like the transmission is in neutral
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat sh
Sep 28, 2016 | Cars & Trucks
Brakes pad's are good but grinding like metal to metal
Semi-metallic brake pads can squeal at times. If it is a grinding you hear however, I ask if you checked the pads simply by looking through to slot in the wheel at the outer pads, or did you actually remove the wheel and check both inner and outer pads. It is not uncommon for the caliper slides to get sticky, causing the inner pads to wear out much faster than the outer pads. Also, if you have riveted pads rather than bonded ones, it can look like you have a good bit of pad left but you may be grinding the rivet heads off. The easiest way to tell is to look not at the pads, but a the brake rotors. Grinding will almost always show as scrapes or gouges in an otherwise smooth and even disc.
Sep 09, 2016 | Cars & Trucks
2005 chevy trailblazer liftgate ...gate tries to keep opening ...hear the motor
you have a cut or bad connection where the wires come from the inside of car and causing a short,so you might have to open the outer cover surrounding the wires,.,,,,,,adrian
Dec 28, 2014 | 2005 Chevrolet TrailBlazer
Socket sizes for the front spindle nut,lower ball,joints outer tie rods 2014 Honda accord V6 touring
it depends on if they have been changed before. normal size is 18mm changed is 19mm on tie rods. also check the condition of the anti-roll bar rubbers as they can cause this problem to. also check the traling arm on the steering this can do this to.
Feb 12, 2014 | Honda Accord Cars & Trucks
Washer say on screen LE and will not turn.. Also when manually turn the turn hear grinding noise too.
Grinding noises are bad. If you are lucky, you got an item (like an underwire support from a bra) between the inner and outer tub, which may be removed through the heater or drain openings in the tub. If you are un-lucky, your rear tub seal failed, causing the rear bearing to fail, or the shaft broke loose from the 3 arms of the spider which drives the inner wash tub. Either of those things is $$$ and a lot of work to repair, involving removal of the outer drum, seperation of the outer drum halves, and repair. (translation: minimum 2 hours labor if you've ever done one before)
Feb 28, 2011 | LG WM-2277HW Front Load Washer
My sony Hadycam vision CCDTRV118 the tape is stuck inside camera and can't remove it
Hello. First, do not force anything!! Secondly, make sure the battery is properly charged. Next, in playback mode, try to rewind or fast forward the tape--this causes the recording, audio, etc. heads to retract away from the tape and *might* free it if that is the cause. When you open the outer cover to trigger tape eject, do you hear the tape mechanism motor running? If you don't hear anything or the mechanism is truly jammed, it will require a tech to remove the tape and repair/replace the insert/eject assembly. Send the unit directly to a repair facility unless the warranty is still in effect.---Hope I was of some help.---Rick
Oct 02, 2009 | Sony Video Cameras
Refridgerater shuts off with a bang
When you look at the compressor of a refrigerator, what you see is actually just an outer case. The compressor is inside that case, supported on four springs. If you give a compressor a shake (even a new one) you will hear the inner compressor part knock on the outer case. Sometimes, if a spring brakes or gets weak, when the compressor stops running, the momentum will then cause it to strike the outer case, causing a loud knock or two. Most refrigerators will work fine for many years if this condition occurs. It is a bit annoying, but the only fix would be to replace the compressor, which is generally prohibitively expensive if the unit is no longer in warranty. Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 15, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Lg tromm
The bearing is pressed in in the factory and is only available as a rear tub assembly. They claim to have extremely tight tolerances to prevent wear and unbalance. Check your owner's manual there may be an extended warranty on the rear half of the tub.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Chevrolet Blazer sound
The origin of this noise is the muffler, it's outer shell expands when it gets out, once you switch off the car it rapidly cools down, and that causes the noise you here.
Jul 22, 2008 | 2006 Chevrolet Blazer
Kodak EasyShare C143 Digital Camera Logo
100 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
