Try resetting the unit by holding down the VCR/DVR button and pressing the STANDBY ON button and see if that helps..
Check if the cables are connected to the correct cables. Your unit cannot play between formats. Also make sure that it is not set to "pure audio mode". Make sure the input selection is correct on your projector.
You should be looking to adjust the "Output" and not "Input" selection on your theatre system, if the source is the theatre system.
Here is a manual for your unit which should explain things more clearly:
http://www.retrevo.com/search/v2/jsp/dow...
Hope that helps! Please don’t forget to "Accept"
the solution if it helped you in any way, or leads you to a fix.
Thank you for using FixYa!
Cheers!
IrishDruid
This leads us to the Onkyo CS-V720's generous connectivity suite. You can hook up a power amplifier and a powered subwoofer to the receiver's preout jacks to get full 5.1-channel sound from DVDs, DVD-As, and SACDs. You also get two sets of analog audio inputs and one out, so you can simultaneously hook up a digital audio player (an iPod, for example) and another external device. A full complement of video outputs (composite, S-Video, and component) and an optical digital audio input round out the rear panel.
Component Tv Hdmi Switching System
HDMI vs. Component: Deciding on the Right Multiroom Cabling - CE Pro ...
What's more HDMI is pushing TV manufacturers to not even ... And, most Component Switching/Distribution Systems include digital audio, often over one Cat5. ...
The Ins and Outs of HDMI
If your TV only has one HDMI input, consider upgrading your home theater receiver to one with HDMI switching for multiple components. ...
Digg - HDMI vs. Component - Assumptions That Mask The Facts
... quality - especially in component you have a very robust system because of the ... a 6 foot run from TV to receiver and both HDMI and component look just as good. ...
Whole Home Audio and Video Switching Using HDMI
... HDMI is fine to connect a cable box and DVD player to a TV, ... In this paper, I will describe a complex system relying heavily on HDMI switching and delivery. ...
Which is Better for HDTV? Component Video or HDMI Connections ...
... is switching or distribution of an analog signal (component video is ... If it were my system, I'd use an HDMI cable between the DirecTV box and the HDTV, ...
The Basics of Home Theater: An HDMI FAQ
... HDMI video data to the TV (you'll need to make sure your set'd DVI input has ... The HDMI v1.3 spec allows for components to ... 1. HDMI video switching ...
Specifications - Bose Lifestyle V30 Surround Sound Home Theater System
... switching for 4 sources (2 with HDMI for DVD and CBL-SAT, 2 with component video, ... Audio inputs and switching for 5 sources (DVD, CBL-SAT, AUX, VCR, TV) ...
Audio Authority & Ultimate Garage - AVAtrix Switching
... provides DVI (or HDMI with adapter) and component video connection of sources, ... System Contents - AVX661* (1) Model 1166 HD AutoSelector w/ DVI and ...
Component Video to HDMI/DVI
... with 4x1 HDMI switching, Composite, S-Video,Component upscaling, more, MM603. EXT-COMA-2-HDMI ... Install an IR System. Connect your Home Theater. Build an ...
Onkyo TX-SR605 HDMI-Switching Home Theater Receiver: Review by Chris ...
... the basic functions of multiple components within your home theater system. The Set Up ... It's Official: HDTV Now an Impulse Buy - the $750 42-inch Plasma TV ...
Bose Lifestyle 38 Series Iv White | Shopica
Find Bose LIFESTYLE 38 Series IV White and other Home Theater Systems at Shopica. Find deals for Bose LIFESTYLE 38 Series IV White and other Home Theater Systems today!
HDMI, Component and DVI switches - Video and Audio Cables and ...
Speakers & Systems. 5.1 Home Cinema System. Cabinet Loudspeakers ... Remote controlled HDMI High definition switching unit with 3 inputs and 1 output to TV. ...
How to get the most out of your HDTV Part 2: Connecting Your HD System ...
Connecting HD components to a TV or home theater system is not as complicated as ... There are many different components that are HDMI compatible: Blu-Ray Disc ...
Slashdot | What's the Matter with HDMI?
... sound system is used, it's still better to route the signal through the TV so ... We commonly get asked, "Whats the difference between HDMI and Component? ...
Component Video Selectors - HomeTech Solutions
... necessary A/V inputs for adding components to your TV and home theater system. ... clear switching of High Definition and Standard Definition component video, ...
Component to HDMI cables already exist, already pointless - Joystiq
... can't even be used to wedge 1080p component video into a TV that only takes HDMI. ... portion of the system is unchanged between component and HDMI so I don't see ...
Accell UltraAV HDMI Connection Solutions - Product Review and Rating of ...
... theater components are useless without good interconnect cables. Check out my review of some excellent HDMI connection ... that made switching between two ...
Set proper display resolution.reset into factory defaults then try.
also check power supply and adapter voltage proper .als ocheck earthing working properly.
You player shifted to progressive scan mode, please use owner's manual to set it back to normal play mode.
let me know if need further help.
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Let me know what cables you are using to connect the receiver to the tv, if you are using RCA cables ensure that RCA video (the yellow one ) is connected in the right way at the back of the system, going to TV video input.
I understood you are using the Onkyo HT-SR800 as a receiver, how do you connect it to the projector?
If you use RCA cables , check the yellow one.
Switch the source selector manually, using either the remote or the buttons on top of the projector.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Z310-Home-Theater-Systems-manual/id/23122dj393/t/2/
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
Dear Ginko ,
Thank you for your response . I should note that there is no television as such . The image is projected on a drop down screen from an overhead projector . This is true regardless of the selected input : DVD , VCR/DVR , CBL/SAT , etc .
Thank You .
Respectfully ,
John P. DeSalvo
Dear Sir/Madam :
Regarding the above -referenced ONKYO HOME THEATER SYSTEM , I wish to add the following :
The video problem persists to the present . However , the overhead projector appears to be functioning properly . It projects the word " OPTIMA " on the drop-down screen . However , when the system is tuned to a television channel , the audio is once again present , but no video . On the lower right side of the screen the following words appear : " SEARCHING FOR SOURCE " or " SOURCE CANNOT BE LOCATED . " The same is true when I insert a DVD in the DVD PLAYER . Additionally , I cannot call up the menu for the DVD PLAYER on the drop-down screen .
Your observations will be appreciated .
Thank You .
Respectfully ,
John P. DeSalvo
