SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
SOURCE: sony kf-50XBR800 tv turns itself on and off
I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
SOURCE: i have a sony xbr lcd projection tv . it goes on
Its symptom of weak lamp that reaches to end of its working hours life span. If lamp has not been replaced in last 2-3 years then replace it to fix tv problem.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
SOURCE: where is the lamp located oa sony lcd projection
the lamps at right side a front of TV.(look like 2 speaker).It,s snap on.
SOURCE: Sony kf-50xbr800 turns on runs
the fault is the power max relay it turns off in cases of internal fault detection there must be an intermit power cross fault it will need to be fixed by a licensed service tech
not what you wanted to hear im sure but im sure this will help
