Hi Dear...........
If you want open any electronice think you need to complete tool box with first ad. If you have a complete tool then follow the mention instruction and open the laptop, if you don;t know anything about laptop then don;t try to open it.
- Reverse the laptop as shown in the figure. And remove the
battery. Open the the screws from back side for the Wi-Fi card cover,
the modem card cover, the memory card cover, the hard disk cover.
- Reverse the laptop as shown in the figure. And remove the battery. Open
the the screws from back side for the Wi-Fi card cover, the modem card
- Take out the Wi-Fi card cover, the memory card cover, the modem card cover, the hard drive cover. Place them at safe place.
- You may require to Open the DVD drive with a paper clip.
Carefully
take out the DVD drive from the computer. In most of the computer one
screw from the back site of the laptop fix the DVD Drive. So you have to
remove all the screw from the bottom of the laptop. - Insert a thin object under the securing strip(keyboard bezel)
and lift it up. Be careful, it may be very tight(there are no screw at
keyboard bezel in most of the cases)
- Take out the securing strip(keyboard bezel).
- Now you can see two screws securing the keyboard and these screws are easily visible remove those screws.
- Now
careful keyboard is connected with flate ribbon cable to the system
board. Disconnect the keyboard cable from the main board and remove the
keyboard.
- Now you can fine one cable(most probably black colors) from LCD and it
is connected to system board. Disconnect the LCD cable from the system
board.
Remove the screw connecting the LCD cable to the base.
Disconnect the flat LED board cable from the system board. - Carefully lift the display/LCD assembly off the base.
The display/top cover assembly - LCD assembly and top cover assembly connected by hinges. - Remove the screw securing the HardDisk holder.
Remove the Hard disk holder.
Disconnect the left and right speaker cables from the system board. - Now remove five screws securing the heatsink assembly for CPU. And disconnect the fan cable from the main board.
- Carefully take out the heat sink off the CPU. And be sure to put heat sink thermal jel /glue when reconnecting the heat sink.
- Remove two screws normally at the corner side connecting the system board to the base
- Now lift of the system board starting from the left side, be careful with the PC card connector.
- Remove the system board off the base.
- Modem card is still connected to the system board with screws securing the modem card. If you want you can remove modem card.
- Remove the screw securing the optical drive holder.The screw is hidden under the black tape.
- Remove the optical drive holder.
- Remove four screws securing the card bus connector (PC card connector).
- Turn the system board right side up.
- Carefully remove the cardbus connector.Unlock the CPU and lift it off the system board.
- Turn the system board upside down.Remove two screws securing the video chip fan.
- Remove the fan cable on the system board.
Remove the video chip fan - Hay great techie guy you have done it.
Video :
Part 1
Part 2
