AOC L22W898 22 in. LCD TV Logo
chris turney Posted on Jan 09, 2012
AOC tv menu locked how to unlock - AOC L22W898 22 in. LCD TV
Angel M Miranda
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 16, 2017
Angel M Miranda
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
724
Points
The TV is locked.. The message is Bottom Locked.
1 Related Answer
yutianyunren
wisiny.com
  • 848 Answers
  • Posted on Feb 27, 2015
SOURCE: aoc e2043 osd locked.How do I unlock? Lt button trick didn't work.
Aoc e2043 osd locked.How do I unlock? Lt button trick didn't work? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
2202130701P AOC 6201 7978301421 Power Supply Backlight Inverter
Menu locked on aoc envision series
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
2helpful
Flat screen tv cant get menu to come up
If there in no menu display, the main digital board to your TV shoule be checked. Contact any service technician.
1helpful
Osd unlock
To unlock the OSD (onscreen display control), turn off the monitor and then press and hold the Menu button on the monitor. Then press the power button to turn the monitor back on. Do not release the Menu button before pressing the power button. This same step (holding the Menu button and then pressing the power button) enables the OSD lock. The menu button is the top button on the right side of the monitor (on the bezel). The power button is the bottom button of the group. AOC has the documentation for the 2036sa here: http://us.aoc.com/monitor_displays/2036sa . See page 20 of the User's Guide for the OSD lock procedure. The picture of the monitor buttons is on page 19. The guide is available as a PDF on the AOC site. Note: you will need Adobe Reader or a similar program to read the file.
I hope this helps.
2answers
Aoc e2043 osd locked.How do I unlock? Lt button trick didn't work.
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. best regards
AOC V22+ OSD is locked
the manual covers this RTM>
most monitors made hold MEMU OSD button 10 seconds and release.
many but not all
now I will read you manual to you, google found and reAD
OR SOME AOC
this should work for AOC monitors
turn off monitor
hold menu and power button together for 10 seconds
turn back on
osd unlocked
1helpful
2answers
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
1helpful
My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
3helpful
2answers
How do you unlock when menu locked appears?
Pres and hold volume ( - and +) at the same time
4helpful
Locked osd
Top AOC Televison & Video Experts
Arnie Burke
Arnie Burke
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
