Posted on Oct 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a KM-3060, I would like to turn off the feature that after I scan a file into and SMB folder, it prints a confirmation page.
Anonymous
Level 3:
Genius:
  • Master 2,120 Answers
  • Posted on Oct 11, 2008
Anonymous
Master
Level 3:
Genius:
Answers
2120
Questions
0
Helped
670011
Points
5011
Browse your scanner defaults menu.
Hi mine is KM 1820 model. It is working properly but evreytime i copy the output is blank and shows only 2 lines
1) Go to IP address. View the Command Center web page. Go to the basic page and register/add a contact inside the contacts book.
2) Provide a name and at the SMB section field, fill up with the host-name or the IP address of the computer, where you need to scan.
3) Fill up the user-name with the local user-name, the one that you use to get it into the computer or create the local user for the PC. That will be the password and user-name.
4) Create a folder where you want to receive the scanned files and add at the path field.
I need to install scanner driver
U can use the scan to file feature for e281c MFP. It will store the scanned file under file_share smb folder.
To access the folder, go to RUN, type "\\IPAddressOfMFP", and u will see the file_share folder
KM-5050 Scanning Issue
the 5050 uses a file scan utility which is basically an ftp utility. you need to download the scanner file utility on each workstation. HERE is the link for the utility and instructions file.
1helpful
Our computer maintenance company was able to set up our scanner about three months ago. Over the weekend we have lost that capability. We are receiving an error message: Setting how do I fix scanning...
Click this LINKfor the Scan to SMB setup guide which will walk you through the settings. If it had been working then stopped most likely just one setting has changed; the two things I would look at first is the password for the folder you are scanning to and and IP/Host Name of the computer you are scanning to.
Does your Domain require you to change your password on a regular bases? If so then the password set in the copier to access the folder on the computer may have changed and the new password needs to be set in the copier.
Also the person that setup the scanning originally may have set it to scan to the IP address of the computer you are scanning to but if the computer is setup for a dynamic IP address the IP will change from time to time and then the copier will not be able to find the computer you are scanning to. Change the IP that the copier is set to scan to, to the Host Name of the computer you are scanning to and that will no longer be an issue.
The Scan to SMB setup guide goes over these settings.
You can also call Kyocera's free help desk Monday - Friday 9 am - 6 pm EST at: 1-800-255-6482.
9helpful
4answers
Unable to access scan folder of Toshiba e-Studio 232 scanner from windows 7 system
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
1helpful
2answers
Need help to setup the scan fuction for Canon Image runner 4570
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
Device does not recognize delivery server
this device does not support scan router v2 lite.
your best bet would be to set up using SMB scan to folder.
set up is pretty straight forward create a folder on the root of C: ie C:scans
share the folder with full permissions, simple file sharing has to be turned off!!
then go into the device web page using the IP address ie: 192.168.xxx.xxx.
go to configuration and smb create a user name ie: bill then point the device to the computer you created the folder on, ie: bill's pc/c:scans
save the configuration log out of the web utility reboot the device and you should have succesfully created an smb folder share.
if this resolves or answers your query please rate me accordingly
good luck and thanks
1helpful
2answers
Can not make bizhub c252 scanning trough e-mail feature
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
7helpful
2answers
KM-1820 scanner setup
The KM-1820 to scan to PC is using SMB, FTP or e-mail.
for SMB:
I am assuming you have the KM-1820 connected within the network and a static IP address for it.
open any Internet browser and go to KM-1820's IP address.
You should see the Command Centre web page.
Go to Basic page and add/register a contact within the Address Book.
Give a name and at the SMB section field, fill up with your computer hostname or the ip address of your computer where you want to scan. Fill up the user name with the local user name - the one what you are using to get into your computer - or create a new LOCAL user for your PC lets say "kyocera". So for SMB will be your computer and username: kyocera. (You will need a password for that computer user (kyocera) ). Then create a folder "scan" where you want ot receive the scanned files and add "scan" at the path field (SMB section of that webpage - command center).
Now share the folder "scan" as "scan".
if you want you can always use the scan to e-mail !! but you need a smtp server. All the settings can be done using that command center webpage.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
