Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
1) clean the c.batteries with c. cleaner 2) retight the spring contacts batteries with long pliers for better contacts 3) open the remote control and clean the keypads for: dirty, corrosion, oxide, and bad contacts. 4) reset the code again. 5) try again. 6) if the problem persist, problem with the Syscon, you must go to repair shop for fix it. God bless you
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers 2) clean the batteries contacts 3) change new batteries 4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
Make sure the light in the wall control isn't blinking. That would be an indication that the lock function is on. To turn it off, press and hold the lock button for 3 seconds.
Hi my nameis Mike Houston of DISH Network and I see your TV2 remote isn't connecting toyour receiver. You will want to make sure you're at the TV1 location to programthe remote for TV2, press the Menu button 2 times and you will see the SystemInfo screen. On the bottom for the screen you will see the remote address forTV2, make sure the TV2 remote has fresh batteries inside. On the back of thereceiver their will be a Remote Antenna port and you want to make sure that ishand tight. Push and release the SAT button and press record and you should seethe address change for TV2. I will send a link to help with these steps; http://www.dishnetwork.com/SupportSection/remote-control.
