TV will not turn on and I think there is a short somewhere. I'm aware of the capacitor problems and positive its not that. I also replaced the power source from shop jimmy.com and have the same problem as before. The red light on the front is constant and when the power button is pressed the green light on the inner back flashes a couple times and then a few clicks and then everything turns off. I then disconnected the connection from the y/x buffer board that runs to the power board and then powered up the TV. The power board didn't short out and weirdly the start-up sound came on with no picture. I'm thinking that I maybe have bad X/Y buffer board because when this board is connected to the power source the TV seems to short out. Thoughts?
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
SOURCE: Samsung LN-T4042H 40 inch LCD TV with cracked panel
Email a request for your part here they will give you a price and part number to order. Good luck.
[email protected]
# NOTE - If this info was helpful to anyone please click on yes!
SOURCE: Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
SOURCE: One day I turned my tv off and it wouldn't turn
The power board is the usual culprit but I have also seen the main board, T/Con board or the panel itself cause this problem. I would recomend calling a trained tech to figure out the problem. You could spend hundreds of dollars on parts and still not fix it. You can call 1-800-samsung to find nearest service center.
SOURCE: blue light flashes 4 times but no power
U know basic electronics,have tools and know basic soldering?Take the tv aparts,the power supply,that board where the a/c power cord plug into it.That the power supply board,searches the power supply board, for those dying about to be dead,capacitors alway bulges up on it tops or puff up on it tops.Replaced these dying and about to be dead capacitors,the tv power will up again and work.Or tries websites like Shopjimmy.com,Ebay,com to buy a refurbish power supply board for the replacement.
