Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have had a lcd tv for aout 3 years recently the screen has been going dark,out of focus on the left side,sometime a line appears across the screen and divides the colour of the picture. What an I do
Sometimes if I gently wipe with microfibre cloth recommended by retailer the problem clears but only temporarily.
    Novelist:
  • 181 Answers
Hello!
the problem is display panel connectors or panel itself(bad case). To solve it, you must disassemble the set till the point, when you will be able to see
t-con(display controller). It, usually have metal shield over it. you need to unscrew those tiny screws, may be remove sticking foil too. After you see the board itself, there are 1 or more flat ribbon cables connecting t-con board to display panel itself. Plugs have plastic locking, fragile! First, unlock the left side(opposite to your view) and pull cable out, then carefully reconnect it. If more, than one, repeat the procedure. got working? assemble everything back. Still have the problem: try to do the same with the other end of the ribbon(s). those, what connect display's boards. You may have insufficient space to reach plug's locks. Invent something to accomplish the task: use tweezers or metal picks. Try not to break anything. In most cases this problem caused by dust/dirt accumulation at those connectors. If nothing helps, I've seen the panels itself doing that. that's the end of DIY project, may be TV itself, unless you purchased extended replacement plan. cost of the panel will void any reasonable repair!
good luck,
thanks,
Alex.
Posted on Jan 10, 2012
6ya staff
SOURCE:
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
May 25, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Dark lines appearing across my lcd tv
This is symptom of LCD Faulty. Please note down cost of LCD is much high. In my suggestion
you change or purchase new TV
Nov 12, 2008 | Televison & Video
Toshiba LCD 37" with gray band and blue line
Unfortunately you are right it is the display panel going bad. You can either live with it or buy you a new tv as the panels usually cost as much or more than the tv. Sorry.
ladytech
Nov 01, 2008 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
121 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
