True GDM-26 Refrigerator Logo
Posted on Oct 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GDM-26 humidity very high
I have a GDM-26 that I plan on using to store wine. I purchased and replaced the thermostat with the one from True designed for red wine. To get the correct temperature setting on the thermostat, I placed a wireless thermometer in the unit. The thermometer also reads the humidity and currently it fluctuates between 85%-95% humidity. This is much higher than I expected and will most likely result in mildew growth on the bottle labels.
Any ideas what could be wrong.
Thanks
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Oct 09, 2008
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
897957
Points
3964
Assuming fridge is at correct temp, i suspect fault is with your humidity detector. the humidity inside a fridge is a lot less than the outside air
2answers
True GDM-49 The unit even with the thermostat set as high as it will go will only cool to about 60 degrees.
You mean 'low as it can go', talking temperature not numbers. The temperature is too high. You need a refrigeration engineer. You either need a top up of gas or the thermostat has failed. They are great fridges, I have had lots of them in my career.
GDM-49-HC~TSL01 - Glass Door Merchandiser - North ...
https://www.truemfg.com > Products > GDM-49-HC~T...
... please change your settings to allow JavaScript. True Foodservice Icon blue with utensils ... GDM-49-HC~TSL01. Glass Door Merchandiser. Compare.
Ajust temp on true gdm 26 f
Hello Tam;
My name is Peter. I am a retired field service refrigeration technician.
The following manual link has the instructions for adjusting your unit temperature.
http://www.truemfg.com/assets/InstallationManuals.../GDM/gdm_english.pdf
Hello Tam;
The following manual link has the instructions to adjust your temperature. You may also have a bad fan or thermostat.
Gdm-26 does not get cold, makes a clicking noise about every thirty seconds from underneath
Replace the thermal/starter relay. It is located on the side of the compressor. It clicks like if you unplugged the unit and plugged it back in quickly causing an over load on the compressor due to the high side still having high pressure and have to wait for a couple of minutes before you plug it in. The relay is at fault. Hope This Helps.
Wiring diagram
Should be under the wiring cover behind the vent slats.
2answers
My true GDM-26 never shuts off and my drinks are frozen?
Faulty thermostat, the thermostats are cheap and wear out easy
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
2helpful
I bought a used True commercial refrigerator model GDM-41 the temp. remains at 60* no matter if i move the thermostat up or down it remains at 60* I noticed that the thermostat was replaced and has a...
Hello Margarito539,
I understand that you purchased a True GDM-41 merchandise refrigerator and you are having a problem with the temperature. The thermostat you are currently using is an in-line thermostat and is not the proper thermostat for the unit I would suggest that you follow the below link and purchase the proper thermostat for the unit. http://restaurant-equipment-parts.com/part/true/800393 the cost is $36.98 and is an OEM part.
You also may need a service tech to check out the freon in the unit. The unit uses 134A freon and must be within a few ounces of charge other wise it will not work properly. As the unit is keeping it 60 degrees, before you do anything make sure that you can hear the compressor running as this is not a cheap fix, however may be worth the cost for the unit you have. The compressor should be humming if it is not and the unit has been plugged in for a while, unplug for about thirty minutes and let the compressor cool. Once thirty minutes has passed plug in and see if the compressor is humming.
After checking the compressor you have two choices if it is humming call a service tech and have them check the freon charge and thermostat or change the thermostat and see if the compressor starts cooling the unit. If the compressor is working then the box is well worth fixing, if the compressor is not working you need to decide if it is worth fixing. A used unit with a one year parts and labor warranty costs $2100 so the repair should not cost over $1000 to be economical.
Thank you for choosing FixYa.com
Justin
We just bought a used True GDM26 that works but it is too noisy
NONE. This is a common complaint from customers who buy commercial units for use in residential atmosphere or quiet stores. These units are made for noisy commercial kitchens, convienience stores, etc.
Fan works, just stopped cooling TRUE GDM 26
there is a leak of gas in the system,must see where the leak is, repair it then fill the gas,
5helpful
2answers
Replacing a temp control valve on a true GDM 26 commercial refridgerator
Unplug the unit & remove the plate holding the thermostat. The capillary for the thermostat will go into a very small tube that runs into the evaporator coil. You will probably not be able to see the tube but will have to feel for it and get a good orientation for where it is located before you pull the capillary out. Try to measure the amount of capillary in the tube as you pull it out so you know how far you have to push the new one in and put some kind of tape or mark on the new capillary before you try to push it in. you might have to soap up the capillary to get it to slide easier.
Top True Refrigerators Experts
ZJ Limited
ZJ Limited
Ngoro
Are you a True Refrigerator Expert? Answer questions, earn points and help others
