SOURCE: Braun Syncro 7680 Electric Razor
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
SOURCE: Braun Synchro 7680 - "Oil" message
Had the same problem on my shaver too. Bought this product:
http://www.onlineshavers.com/pd_braun_8000_activator_foil_cutter_pack31.cfm
(I know the link says foil cutter, but it takes you to Braun lubricating oil!)
I apply the lubricating oil to the foil etc, then the word "oil" disappears. Then after a while the word "oil" comes back and I apply the oil again and so on, my shaver still performs normally.
Hope this helps.
SOURCE: I have lost my instruction and cleaning
Here are the instructions for a #7680 Shaver. http://www.service.braun.com/line/SH/S5491/S5491_9_NA.pdf
SOURCE: My Braun 7680 says "Oil"
Yes, drizzle some vegetable oil on the blades while running.
Testimonial: "Fast and easy. GREAT!"
SOURCE: I have a Braun 7680, and the switch won't work -
Most likely, the mechanism is broken and will need replaced. The switch is part of the trimmer assembly which comes attached to the outer casing. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-body-housing-select-models-p-811.html
You will also find disassembly tutorial at the link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
You will find the oil at shaveroutlet.com. Seelink below
http://shaveroutlet.com/shaver-accessories/braun/braun-shaver-oil-p-465.html
Oil is applied to the foils. About a drop per week
