I have a dell poweredge 1800 server with a 3gb xeon cpu and 8gb of ram that will not finish setup for Ubuntu 11.10 32 bit server (because i may be useing flash). It just stops and shuts the system down after a few min at the first ubuntu loading page. i have checked the disk and it checks out fine and i am shure it isnt the dvd rom as well. any ideas of what this may be?
SOURCE: dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
SOURCE: DELL Poweredge 2600 Bios FREEZES After Cpu check and before SCSI Drives check HELP!!!!
The BIOS check can freeze for many reasons.
Can you tell me if this is an existing system that was working fine and then had this problem, or is this a new (or new to you) system?
Can you give more information on what is actually showing on the screen?
SOURCE: Valid operating systems fro Power Edge 1800
During the Windows XP setup you will need to provide the RAID driver using a pre-formated floppy disk.
Windows will ask you if you want to provide additional drivers and give you the key combination to use to do that.
SOURCE: Can ubuntu be installed on dell poweredge 2850
yes Ubuntu can be installed in Dell poweredge 2850 server
SOURCE: Heres my issue ubuntu server will not install on
you can refer to Ubuntu or Dell for further help or support
Testimonial: "Thanks very much"
