Question about Uniden Cordless Phone
Intercom uniden D1688
Set up intercom
    New Friend:
After reading the manual over and over with no success, I got the hint to successfully do an intercom call by reading a post from a website.. The manual says to press the Intercom buttom. Then select the phone you wish to intercom with (or All phones) - do this by using the up-down button. The step left out of the manual is: THEN press the MENU key. It works perfectly!!
Posted on Feb 26, 2013
2 Suggested Answers
6ya staff
SOURCE:
Gale Todd
  • 1116 Answers
SOURCE: Bought a new Uniden D1688-2 but lost the manual.
You can find your manual at the link below:
http://uniden.com/pdf/D1688-2om.pdf
Posted on Jun 16, 2011
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
Where does the Ans system ask me to select ans select or record greeting on my uniden phone d1688
With the phone in standby mode, open the menu by pressing MENU/SELECT. Select "Ans. Setup." Press MENU/SELECT to start recording. Press MENU/SELECT when done. Press PLAY/STOP on the base or END on the handset to save.
The above is from page 18 of the manual.
Jun 12, 2012 | Uniden D1688-2 Standard Phone - 1.90 Ghz -...
I have the uniden D1688 phone and the ringer will not ring
I went into the menu and turned off the personal ringer. And that worked for me. When you set up a caller into the phone book it ask you for a personal ring tone. If none is selected none will ring.
Jan 01, 2012 | Uniden Lands Phones
I purchased a Uniden model D1688 and I don't know how to put favorites into the phonebook.
Entries can be added from the base or the handset. The CID button is on the right of the control ring; the phonebook is on the left of that ring.
If you want to add a number from the Caller ID list to the phone book, press CID and use the up/down arrows to navigate to the call that you want to add. Then press Menu/Select. Select the line Store into Pb and press Menu/Select. You will be at the Edit Name Screen for the phonebook.
To enter a new item from scratch, press the Phonebook button. Then press Menu/Select and select the Create New submenu. Press Menu/Select and enter the name of the contact using the alphabet on the key pad. (For C, press 2 three times.) Press Menu/Select and enter the phone number as it is dialed (including a 1 if needed). If you need to add a pause in the number, press Redial/Pause. However, the entire number must be less than 20 digits (including the pause). Press Menu/Select again. If you enter the number from the handset, you will be prompted to select a ringtone to always use when you get a call from that number. Press Menu/Select again. Then press End (on the handset) or Play/Stop (on the base) to exit the menu system.
Uniden has the manuals available at their site, either from the product page or the support page. All DECT phone manuals are here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manuals are listed in numerical and alphabetical order. The direct link to the D1688 manual in English is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1688-2om.pdf .
I hope this helps.
Aug 30, 2011 | Cell Phones
How do I exit "Silent" on phone model D1688.
Press and hold SILENT on any handset then select "Always on" at the prompt.
The instructions are on page 14 of the manual at
Jul 18, 2011 | Uniden Lands Phones
I own a uniden dect 6.0 cordless phone with 4 hand helds..i want to start using the answer machine part,,but have lost my start up manuel..can you send me 1 please..this has been a great piece of...
Here is a link to all the Uniden cordless phone user manuals on the Uniden Support website:
http://www.uniden.com/scat/cordlessphones_mnl
And here is a link to the support page for a Uniden Dect 6.0 (Model D1688-2):
http://www.uniden.com/cordless-phones/dect-60-cordedcordless-phone-with-digital-answering-system-expandable-up-to-12-handsets/invt/d16882g/
And here is a link to the user's manual for that phone:
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Jul 18, 2011 | Uniden DECT 6.0 Cordless Phone ID
Uniden Cordless Phone Logo
145 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
