This is probably a model that has two access holes at the bottom front of the dryer -about 4-5" from each side- usually closed off with plastic discs. Just an inch up from the washing machine. Pry out the plastic discs with a flat screwdriver and you should see a screw inside each of the two openings. Remove the screws and you will be able to tip the dryer up and slide it back a few inches to detatch from the back.
Use two people to lift the dryer down as it is bulky but not too heavy.
