Help!! I was trying to program the speed dial function on my phone and now the co 01 won't pick up the outside line (which it was originally assigned to) I used to be able to lift the receiver and co-01 would light up now nothing. Thanks in advance for the help.
Remember that PROG 13 you pressed? First, press PROG and touch CO-1's button and make sure it still say CO-1. If not, dial 01 STORE and it will become CO-1 again.
Now, pick up the handset and hang it up so you clear the phone and press PROG 13 1 STORE PROG
Easy when you have the manual :-)
Carl
Thanks for the rating. The button programming is in the manual. If you have a TA system, this manual will work
www.microtelcommunications.com/linked/ta_om.pdf
Page 157 lists what you can do with the buttons and how to program them. The high spots are 0 for CO, 1 for EXT and 2 for speed dial. Because the PF buttons can only program speed dial, the "2" is assumed.
If you get confused don't hesitate to write back!
Carl
The right side buttons already have a "2" assumed, so you press the button and dial "9" plus your number then STORE. If you are using left side buttons (don't do it!!), then you dial 2 + 9 plus the number. You may also substitute 8x codes for 9 if you want to dial out on a specific line.
islea425 the programming is the same....after you dial PROGRAM 99.
Carl
Carl I LOVE YOU!!!
PS I have the manual Still can't figure out the one touch dialing :-( or the intercom one touch for that matter
I have the same problem. I was trying to set up a speed dial and I messed up my line one only i have the KX-T7433 Panasonic phone.
So your instructions for the other post did not work for me. Can you help?
Hey Carl
I am still having trouble setting up the speed dial buttons I am following the directions on page 157 in the link you sent me. I can't figure how to set it up so the co is in front of the phone number.
This is what I am trying to do:
Program, co, 01, 2, 1818903.... store , program
I am getting a double beep after the "2" and it won't let me continue.
What am I doing wrong?
Thanks
Lisa
I can not get the speed dial programmed - please help
KX-T7731 I messed up the co button. I read your following instructions, but I don't have a store buttom. What should I press to store on the KX-T7731? Please help.
(Remember that PROG 13 you pressed? First, press PROG and touch CO-1's button and make sure it still say CO-1. If not, dial 01 STORE and it will become CO-1 again.
Now, pick up the handset and hang it up so you clear the phone and press PROG 13 1 STORE PROG )
The co button when I used to pick up the handset was #4
