Question about Ovens
Oven doesn't work.
My tappan stove top works, but my oven has stopped any idea why?
  • 943 Answers
HI. thanks for your question. i would replace the 2. 30 amp fuses in the stove. try that. if not repaired. check the timer. it must be set to MANUAL, for the oven to work, check that.thanks the appliance doc. please rate my answer. thanks
Posted on Oct 08, 2008
6ya staff
SOURCE:
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
My tappan oven won't work. stove and broiler work fine. ignighter glows but it seems like there is no gas.
I would check with your manufacturer and see if a professional can diagnose the regulator and even the gas valve itself.
Jul 17, 2012 | Tappan Ovens
The inside oven is not heating. The top burners are working fine.
If this is an electric oven, most likely the oven bake element has burnt out.
the model and serial number should be behind the bottom drawer,
most elements are held in with (2) 1/4 inch socket hex head screws.
Remember to unplug stove or shut off breaker before servicing.
The element can be slid out usually, then unplugged or remove
the back cover behind stove and unplug it from the wiring harness.
I hope this is useful
Aug 02, 2011 | Tappan Ovens
Stove top works but oven doesn't
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 13, 2011 | Tappan 30IN ELEC IGNa Oven
Does this tappan stove require a hood for ventilation? The one I have is intalled in the center island of the kitchen.
You don't have to have a hood over a stove. If you do though it removes all steam and odours. The grill also catches all the cooking fats. Your kitchen will stay a lot cleaner if you have one.
Feb 11, 2011 | Tappan 30IN ELEC IGNa Oven
Installed a new Tappan stove electric
check if there are links on the mains connector block and if so, make sure they are tight
Aug 10, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Tappan oven won't turn on after cleaning
I don't precisely understand...responding. I assume that if you say oven on that the oven isn't heating but the indicator controls are working. This has several possibilities. First, do turn your circuit breakers off then on...there are two linked together. This may reset something. If that fails, your problems are likely in either the high limit safety switch or the heating elements. The elements are more likely. To check them, turn off the power and remove them from the oven. This is usually by taking out one screw and unclipping the element. See if the element is bulged or damaged. If not, use a multitester to see if one of them is not conducting. Replace it. High limit should conduct fully. Use the curcuit diagram on the stove to determine its location.
Dec 27, 2007 | Ovens
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
247 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
