Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
And here's a video summary of the steps:
No solution,.. but here was my problem. just got done loading pics onto computer. deleted them off camera. I pulled out the cord, and (probably the way I was holding it) the camera turned on, the lens came out and done. it has not worked since. I even tried charging the battery. I think this is the reason camera is so cheap cuz they stop working right after a while. mine is not even a year old. brought it back to Cosco and I have to on trouble shoot before they even take it back (returns are not accepted after 90 days on cameras)
SOURCE: Canon Powershot SX10 lens error
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards iversh
if you felt i've spent my time for u... a very helpful rating is appreciated...
SOURCE: Digital Camera
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: lens stuck
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
SOURCE: Canon PowerShot SX 100 IS lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
SOURCE: "lens error, restart camera" for canon powershot SD1200IS
problem in canon digital camera ixus 95 is
Do not open Power has never changed the battery and another also does not start
