SOURCE: please assist me in setting
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
SOURCE: BRINKS MODEL 42-1020 A 24-HOUR TIMER WITH 15-
Not sure what your problem is exactly....is it not working? You don't know how to set it???
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
SOURCE: Have a timer that I
Move the dial clockwise until the arrow (marked TIME OF DAY) is lined up with your present time. Numbers on dark gray background are night time hours. Depress outer "teeth" that also correspond with hours of the day & evening (ea. tooth = 1/2 hour) for the chunk of time(s) you want the appliance ON. Plug timer into outlet and appliance into timer. There is a manual TURN ON slide switch on the left of the timer for your convenience as necessary.
SOURCE: Need how to use my timer. Brinks digital plug in
Manual appears on following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: i have a brinks timer
1) Open following link to identify timer and download possible manual:
2) You can contact Hamptonproducts.com and they will send manual.
3) If you have a manual and cannot understand it, then add a comment and say what part of manual is confusing, and what you have tried so far, and what load you are wanting to turn on-off. Not every timer is right for every application, so clear identification of what you want to do is best.
Upvote the help.
And take advantage of fixya expert assistance live.
