Elna 2005 Mechanical Sewing Machine Logo
A
Anonymous Posted on Jan 06, 2012
Elna type 2005 replace bulb
How to replace light
Bulb seems in working condition but light won't come on, should it do it automatically the machine is switched on. Old elna contessa just picked up
it sounds like a part of the sewing machine in broken. Try switching power outlets and double checking that the bulb has been tightened . If there are still issues, please setup a repair with Elna by calling this phone number: 1 (800) 992-2991. Thank youl.
1helpful
How do I change the light on Elna 6003. Can I use a LED bulb
An LED bulb, https://www.sewingpartsonline.com/led-bulb-janome-mc9000-led.aspx , is available for the Elna 6003. To replace the bulb, you need to remove the left side face plate. The screw holding the face-plate is hidden behind a button that matches the face plate. Next pull the socket out. Then pull the bulb out of the socket. Push the new bulb into the socket with the pins aligned with the holes in the socket. Push the socket back into the sewing machine and replace the left-side face plate. For an idea of the procedure, see the manual for the Elna 6001, available at ManualsLib. https://www.manualslib.com/manual/378188/Elna-6001.html?page=53 . This is the maintenance page of this manual.
I hope this helps.
How does one change the bulb on an elna 6003 sewing machine
Hopefully you have a manual that shows how to replace the bulb. Online Elna manuals have a fee.
Perhaps something here will help:
Change bulb elna 6003q
How do you change light on elna 6003 sewing machine
Watch Me For Minute Elna Lightbult Change
1helpful
How can I replace lamp?
The owner's manual should have instructions how to replace the bulb, but sometimes that information is not provided. However, this link may be helpful:
Elna quilters dream 6003 apart to replace light
7helpful
I need to replace the light bulb on my Elna SU 62C sewing machine and I am not sure how to remove it. Has been in the machine since I purchased it in the early 70s.
Switch power off first. On the top left hand side of the machine towards the front is a small hole. Insert small screwdriver in hole and push down. The light bulb will appear underneath just to the left of the presser foot. Whilst holding down the screwdriver firmly, turn bulb anti-clockwise pushing slightly upwards at the same time. Bulb should dislodge.
2helpful
Elna carina how to remove light bulb
There is a small hole on the left side of the top of the machine. Using a thin rod such as the L shaped edge guide that came with the accessories, push down in the hole and the lamp socket (which is spring loaded) will go down to allow you to grasp the bulb. Replace it with a similar long bulb available at any sewing machine repair shop.
1helpful
I have an Elna Super sewing machine that was my mothers. I do not have the manual and need to know how to change the light bulb. Thanks.
I have an Elna TSP (about 35 years old) that I believe is about the same as yours. There is a small hold on the top of the sewing machine (not an oiling hold) near the front. Use the small screw driver that came with the machine and push it down into the hole. The light bulb will be pushed down in back of the needle. The bulb has a bayonet type socket and you have to push up and twist the bulb to remove it. This is not striaght forward and you really need the owners manual to figure it out. If you do not have the original screwdriver, one from an eyeglass repair kit might work. I found your question because I am trying to locate a replacement bulb for my Elna.
14helpful
2answers
Cannot get to the lightbulb on an Elna SU sewing machine to chang
On the left hand side of the machine on the end cap.
Changing the Light Bulb
The sewing light is located behind the face plate.
UNPLUG THE MACHINE. Wait until the bulb is COOL before you touch it!
1 2 3 Remove screw cap , screw and face plate .
To remove: pull out bulb from socket.
To replace: insert bulb into socket.
Attach face plate and insert screw and screw cap.
NOTE: Replace bulb with same type rated 12V, 5W.
I hope this helps. Don't forget to rate my answer.
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
