Weiser Lock Powerbolt 1000 Lock Logo
Posted on Jan 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lock has started to work backwards....the code locks it and the lock button unlocks it. Changed the batteries....no help.e
Anonymous
Level 3:
  • Master 963 Answers
  • Posted on Feb 23, 2012
Anonymous
Master
Level 3:
Answers
963
Questions
0
Helped
489057
Points
1500
Remove the cover. On the right hand side under the batteries you will notice that it says "Door Direction Jumper". If the jumper is located across prongs 1 & 2, move it to prongs 2 & 3, or vice versa. This controls the direction of the operation which makes the lock universal to doors with the hinges to the right or to the left.
1 Related Answer
Anonymous
  • 68 Answers
  • Posted on Mar 23, 2009
SOURCE: kwikset keyless entry is backwards
The config terminal is wrong. Take the cover off and move the 2 pin terminal over one pin.
Citroen Relay central locking issue
well. why have only just one fob>?
the fobs die at 10 years old easy.
the buttons inside ,mine failed now 2times.
2015 to now. mine.
the buttons have switches in mine, gold plated
and the gold now looks like shot gun blasted. (under a microscope)
as in END OF LIFE worn out. all fobs do that.
or battery new is bad or battery in backwards
or battery clips bent or rusty
never have only one fob. (or land here x)
2helpful
2answers
I just bought your defiant electronic deadbolt. It works backwards ... Lock is unlock and unlock is lock ... I've been working this for 7 hours!
I would recommend taking the deadbolt back to wherever you purchased it from and exchanging it for a new one. It sounds like you got a defective unit.
Just so there’s no confusion, this website is a general question-and-answer site for anyone who needs help fixing something. It’s not the customer service website for the manufacturer or retailer you got your deadbolt from. I do not represent the manufacturer or the retailer. I’m just a random guy on the internet trying to help out. :)
2helpful
Weiser Power deadbolt works backwards on keypad
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
1helpful
I changed the key batteries for my 1999 BMW 323i after they died. Afterwards the remote unlock and lock won't work, the car also won't start but it can turn over/on and the radio and the lights...
stick the key in the ignition, turn it to the on position, remove it within 5 seconds, then hold the unlock button down and press the lock button 3 times within 10 seconds and release both buttons. The doors should lock/unlock to give you confirmation and your key should work.
76helpful
9answers
Micromax i am forgotted my phone lock code
Micromax q75 phone lock ? : Solution: If you have not changed the default phone lock code for your micromax q75 phone. Then use "0000"(four zeros is the default code) and press the home button(top left most button and not the green sim 1 button). If you press the green button it will say " Emergency calls only" it means you are clicking wrong button. hope this helps you.
Remote got wet in salt water. Had battery changed
Programming
When
Key added or replaced. System malfunction.
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 5 seconds: Insert key into ignition switch, then remove it. Within 40 seconds: Close and open driver's door twice. Insert key into ignition switch, then remove it. Within 40 seconds: Close and open driver's door twice. Insert key into ignition switch. Close driver's door. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Carry out the following button procedure within 40 seconds: Press key lock or unlock button once. Within 3 seconds: Press same key lock or unlock button once. System should now lock and unlock vehicle.
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat button procedure.
If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Open driver's door. NOTE: A maximum of 4 keys can be programmed
This will work providing printed circuit is not damaged in remote
Change battery and key not working anymonre
Close all doors.Switch ignition on and off,Press and HOLD unlock button,press lock button 3 times in 10 seconds.Release unlock button.Central locking will reactivate.If it does not work first time try again.Before you start i take it that when you press any button the led flashes to confirm that this battery is ok.If more than 1 key is to be programmed it must be done within 30 secs of first.When replacing a battery it must be within 60 secs atfter removing old one otherwise it loses code,Also when replacing battery do not press any buttons.
1helpful
Hi i have a bmw 320ci 2001 and sometimes when i get in and turn ignition on it wont start. i've found the only way to make it start is by pressing the lock and unlock button a few times. hope you can help....
Have you ever changed the battery in the key fob? Next time you go to start it unlock it by using the key in the drivers door lock turn to the unlock position and hold there your windows will lower and sunroof will open. Get in and start car if you do not have to lock/unlock to start change the fob battery if you do need the lock/unlock move your chip in your key is bad
3helpful
2answers
Center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Top Weiser Lock Locks & Locksmithing Experts
Sean Wright
Sean Wright
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
