Require a manual for a cool model no / 438656 please
Recent Carrier Xhb123d Xy Series Heatcool Air Conditioner ...
domecrel.com/recent-carrier-xhb123d-xy-series-heatcool-air-conditioner/
Download Your Carrier Manual - Oge. Recent carrier xhb123d xy series heatcool air conditioner Heat ?^' enables the heating equipment to operate as needed.
SOURCE: Info ob use of this product
window ac unit,,,,,,,not much to do with them turn it on if it cools ure good if it dont check the filter,,,,,,,,,unfurtunately with the labor costs and prices of freon the window units pretty much a not worth the service fee item just dispose of it and buy a new one when it craps out as for disposal a sighn on it at the end of the driveway saying free scrap metal will usually get the attention of some junk removel scrap guy xxxejxxx
If you still require a book the number that i have for the company that supplies this unit is: 0121 565 7772. It may be out of date but it is worth trying.
The magnetron may have either failed or
is not being supplied with the extremely high voltage required to run
it.
The cooling fan and turntable motor get their supply from the same point as the main transformer. If the magnetron or diode has failed that will cause excess current to be drawn and take out the supply fuse.
Make sure the !!!!capacitor is discharged!!!!!
before attempting any sort of repair.
Check the door interlock
switches first then the high voltage diode with either an AVO model 8
on high resistance range for short circuit, the feed fuse on the
primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
did you get manual as i need one?
