Model MP50 Type 4 154
SOURCE: manual for an OscarJuice Extractor ?
Here the manual for Oscar 900 that is quite similar, the operations and recipes should be the same.
SOURCE: Need instruction for this braun juicer type 4154 model mp60
Hi. I've checked online with Braun and there's no Owners Manual available on their website anymore. I own the same model (rebadged) and find it excellent.
The best I can offer you is a Service Diagram with an exploded view of parts.
SOURCE: I need manual to learn how to use it
If you Google your query you will be able to find the manufacturer, they should be able to help you with a manual for this model. I hope this is of some help.
SOURCE: I purchased a Hamilton Beach juice extractor, Type
The solution i have found is relatively simple, but going to take a bit of handy work.
first, it would greatly help to remove the bottom from the unit. You will need to remove the 4 rubber pads, and then the 4 screws. 2 of the screws are way up there and need a thin philips.
Regardless if you removed the bottom, you will need to drill a hole right in the center of that circular grill on the bottom piece.
If you did NOT remove the bottom piece, I would take a nail, clamp it with vice grips, get it red red hot off the burner, and burn away that center plaster to create a hole. So whether you drilled the hole (with the bottom removed) or burned the hole (with the bottom intact), you will see the bottom of the motor has a slot head.
Now, all you need to do is take a thin blade screwdriver, or thin butter knife into that slot, holds the motor, then twist the blade right off...or on...whichever the case may be.
Hope this helps...sure helped me!
SOURCE: Braun MP50 juicer problems
I suspect you have solved the problem by now, if not, this worked for me. First unscrew the white center screw. Then as you lift up on the metal basket you should see the black center screw lift slightly. while holding upward pressure on the basket, tap the black center screw down. the basket and cutting disk should pop free. hope this helps.
