SOURCE: help me find driver for GIGABYTE GA-945GZM-S2
You can download the drivers from Gigabyte WEB support site, select your model motherboard to download :-
http://www.gigabyte.com.tw/support-downloads/support-downloads.aspx
SOURCE: enable to boot bootable usb drive,ga-945gzm-s2 motherboard
reset your bios inside your pc its a big watch battery take it out for 10 15 min then put back it if that does not work take out the battery again and if you see neer your battery was ther should be a small jumper its usually black and its plugged in your board it also should have 3 pins to plug it in when you take it out plug it in the next 2 pins (the miffle one will plug in aswell then put it back in the first pins again put battery back in an try to boot it should work...
SOURCE: i want the mother board lan ethernet driver of
You can download the drivers from Gigabyte WEB support site. Please click on this link and select your model motherboard and drivers you require :-
SOURCE: please give me the motherboard
Gigabyte hasn't made available the Windows 7 drivers for the GA-945GZM-S2 as of yet. You can try to contact them and see if they will eventually provide them:
http://tw2005.giga-byte.com/Company/ContactUs/contact_us.htm
It's possible that the Vista drivers may work, but there is no guarantee on that:
http://www.gigabyte.com/products/product-page.aspx?pid=2425#dl
If you have Vista, you can install the Vista drivers, then try to upgrade to Windows 7 from Vista. Here's a tutorial that may help:
http://windows.microsoft.com/en-US/windows7/help/upgrading-from-windows-vista-to-windows-7
