I'm having trouble printing from my Kodak EasyShare M530 when I connect it via USB to my Polaroid Pogo printer. The Pictbridge logo should appear automatically but it doesn't - instead the screen goes black for a second or two and then returns to normal. I've tried everything and can't get any answers from Polaroid or Kodak, please can someone help!!
SOURCE: 2 Problems: 1) Unable to get printer to print from desktop; 2) Kodak SW won't install on laptop
Download and install the new software and printer firmware from kodak.com (link below - firmware and software is the same for all the 5000 units). Do not use the CD, and Uninstall all previous versions before installing the new software you download from the site.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=mac_os_x_10_5_x&downloadLanguage=en
I hope this helps. If you still have problems respond to this message with what happens and I will try and get you more help
SDtester.
SOURCE: Printer Kodak Easyshare 5300 Will not print black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
SOURCE: Have just bought a Pogo printer.
If you are printing from a PC/Mac via Bluetooth, It won't accept anything other than Jpg's and also if the file name is too long (or if the file has multiple .'s in the name as I just found out)
SOURCE: can i print pictures from panasonic dmc-fz18 using
you have to put the camera in view mode first ...and select pict bridge ..than follow the instructions on your camera ...probably will have to accept connection or confirm transfer ..
Also, I can't do anything to change the USB settings on the camera!
