Measuring Tools & Sensors Logo
Posted on Jan 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a model 265NC National Geographic Weather station and the outside info doesn't register are there batteries in the outside unit?
Marty Warge
Level 3:
Master:
  • Master 561 Answers
  • Posted on Dec 21, 2019
Marty Warge
Master
Level 3:
Master:
Answers
561
Questions
Helped
187942
Points
1881
Sometimes the weather brings us surprises. For example, it is sunny in the morning bet when you leave your office, it is snowing outside. So, it can spoil our evening. In such cases, snow day finder is necessary because it can warn you about future weather changes.
5 Related Answers
Anonymous
  • Posted on Sep 07, 2010
SOURCE: national geographic Weather analyzer software help
be shure that you have fresh AA battries in both the reciver and the probe.. also first power up the reciver befor you install the software.
Anonymous
  • Posted on Nov 16, 2010
SOURCE: Omnitech Wireless Weather Station model
Push and hold down the channel button, wait for beep, then on the sensor, push and hold the tx button, wait for beep.
kerguney
Kazim ERGUNEY
  • 577 Answers
  • Posted on Jul 19, 2011
SOURCE: I have a 00594 weather
hi.
I assume that you have used some fresh batteries,it is recommended to replace both indoor and outdoor unit to get a best result....after replacement you need to reset it..
I do not know if you have the instruction manual for your unit however just in case I hereby included a URL link for you to download it..
THIS LINK LINK WILL GIVE YOU THE USER MANUAL. ITS IN PDF FORMAT THIS WILL SURELY HELP YOU TO SET UP .
Take care and please Remember to rate/vote and give
me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://theguidedb.com/search/the-acurite-weather-stations-00594--wa-guide.html
Anonymous
  • Posted on Nov 06, 2011
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
Jim Dowell
  • 345 Answers
  • Posted on Aug 28, 2017
SOURCE: National Geographic radio controlled weather station Model # 265nc transmitter will not communicate between station and the transmitter?
There is a battery in both the transmitter and receiver. If either one of them is weak then it won't sync. I would try replacing the transmitter battery first.
1helpful
AcuRite Professional Weather Center 01602BPDI. It eats the outside batteries. Batteries last about 2-3 months till low battery power shows inside with -40 degrees plus other false readings.
My National Geographic Weather Station is the opposite. The outside sensor only indicates the temperature, but the single CR2023 battery lasts a year. The inside unit on my desk lasts around 5 - 6 months and lets me know if needs a battery by showing the outside temperature as ' -- '
Although the manual says 'rechargeable batteries are not recommended', I would try 4 Sanyo Eneloop batteries. Or you could contact Acurite Support and ask them if your battery use is excessive?
01602BPDI - Professional Weather Station Instructions
AcuRite.com https://www.acurite.com > 01602-instructions
Professional Weather Center model 01602BPDI. Questions? Contact Customer Support at. (877) 221-1252 or visit www.AcuRite.com. SAVE THIS MANUAL FOR FUTURE ...
2answers
Software for National Geographic 265NC
I tried the software that came with the National Geographic weather station 265NC but found it not what I wanted for history data. I downloaded Cumulus software from Sandaysoft.com I have used it since 2009 and have had no problems. When setting up the station on the software use Fine Offset as a menu selector for type of station as that worked for me.
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Top Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
