The paper jams everytime I try to print. it tends to pull to the right, and wont go all the way through. what could be causing this problem and hiw can I fix it? I inspected everything and tried sliding an envelope through and nothing works. This morning it printed one page and then jammed again. HELP!! Iris [email protected]
I also did the shaking. It did not work the first two times, but the third time I shook it more aggressively. I did not see anything pop out or drop out, but it did fix the problem. mbyers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
842
I just did the same and turned the printer upside down and shook for bout ten minutes,,, wah laa yayyyyyy it is pulling the paper thru nicely now,,, ty ty
I took one of your readers advice, unplugged the printer, turned it upside down and shook it.
Out popped a push pin and my problem was solved.
Thanks a lot for your help.
Iris
I bet that there is still some paper or something else stuck in the lower back portion of the printer. This section appears to be inaccessible to non-techie humans (us!). One person said that turning the machine upside down and shaking forced to piece of plastic to drop out and that solved the problem. You might check with a flashlight to see if you see any paper visible deep down inside and perhaps prod it or cut it with a long knife and shake it to get the pieces to come out. Sorry that i can't provide a more elegant solution.
Leading cause of paper
jams is debris / foreign objects that accidentally fell into the paper feed
area. Please try this approach to fix the problem:
same issue nothing works any advice?
My printer started to jam after I reloded paper.As though only right side being fed through and left side being dragged.paper then starts to crumple and then jams. I have cleared jam checked for paper debri changed paper but it is still doing it. Having difficulty checking rollers as out of reach.
my paper tends to start coming through on the left side but then it stops all together and it says paper jam i have removed everything and followed the advice to try and do it manually but it continues to say the thing over and over.
Hi trobb49
Just wanted to say thank you so much for your solution. I turned the
printer upside down and shook it and out popped a push pin!!!!
Thanks for saving me a good deal of repair money and I hope this will help others.
Iris
