SOURCE: i have a crown ce 2000 watt amp. channel 2 keeps turning off
Do you get any Fault indications?
Have you swapped the speakers around to eliminate them as external causes?
When the channel dies is the unit very hot and is the fan turning very fast (it should be if hot)? The fan could be defective, slow or airflow may be restricted.
Turn the amp off and examine the fan guard on the rear to make sure it is clear of dust and debris. Vacuum it out if necessary. With a small thin non-metalic object reach in and test the fan for free movement by trying to rotate it. It should coast.
SOURCE: how much watts is
A simple web search for "crown ce-2000 spec" yields several documents with full specs into various loads.
http://www.crownaudio.com/pdf/legacy/136705.pdf
http://www.iceco.com/Crown/CE2000.pdf
SOURCE: fault light on my crown ce 2000 is on both
It sounds like your output transistors are bad or power supply problems. You will need to have it serviced unless you know about electronics and how to repair them. Do not attempt this yourself unless you know what you are doing. It could be fatal.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Crown-CE-2000-Amps-manual/id/22150ag314/t/2/
See page 21
