My display has horizontal 1/4 inch bands which look like a picket fence. When I am in Explorer or some other app often times after I have placed the cursor on the tool bar, etc. it will turn yellow. I can still see everything and thus far everything seems to operate okay. Things done: 1. System restore 2. Drivers reloaded 3. Numerous reboots 4. Same problem in safe mode 5. No indication of anything not working correctly in Systems Folder
SOURCE: Vertical lines in my laptop screen
This appears to be a duplicate posting, see this link for the active post: http://www.fixya.com/support/t152864-vertical_lines_in_laptop_screen
SOURCE: compaq presario 5000 not booting up right.
Does the Compaq logo appear when you try to start the computer? Try pressing F10 several times after turning on the power. This should start the "recovery console", which will give you some options for restoring Windows. If the recovery console doesn't start up, there is a good possibility that your hard drive or power supply module may be defective. In that case, you will probably need professional assistance to diagnose the problem.
SOURCE: drivers
This model of Presario has an audio controller that supports the high
definition audio. You
need to have Microsoft Universal Audio Architecture (UAA) Bus Driver for
High Definition
Audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver
that need to be
installed before installing the audio driver:
ftp://ftp.compaq.com/pub/softpaq/sp30001-30500/sp30301.exe
or
ftp://ftp.compaq.com/pub/softpaq/sp32501-33000/sp32646.exe
or
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=PSG_I22669-107348&jumpid=reg_R1002_USEN
Note: Please copy the entire link starting from "ftp" to "exe" and paste
it in the address
bar of the browser in your computer and press enter.
Conexant CX20549-12 High Definition Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
it in the address
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click
Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from the
list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp36090 folder and select the .inf (wis30b2a)
file and click open and Continue with the onscreen instructions.
Similarly install Modem Drivers:
Conexant CX20548 Modem Driver for Microsoft Windows XP
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
1.Right click on "Modem device on High Definition Audio Bus" and click
Update driver.
2. Select "Install from a list or specific location"
3. Click Next. Then select "Don't search, I will choose the driver to
install"
4. Click Next and then select "Modem" from the list.
5. Click Next and then click Have Disk.
6. Click Browse C:\swsetup\sp33890 folder and select the .inf (wis30b2b)
file and click open
Video:
http://downloadmirror.intel.com/14388/a08/win2k_xp14311.exe
k
Chipset:
http://downloadmirror.intel.com/13799/eng/ChipUtil.exe
Intel Pro Wireless:
ftp://ftp.hp.com/pub/softpaq/sp33001-33500/sp33404.exe
or
ftp://ftp.compaq.com/pub/softpaq/sp33001-33500/sp33404.exe
or
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32156.exe
or
ftp://ftp.compaq.com/pub/softpaq/sp32001-32500/sp32156.exe
Note: Please do not click on the link. Copy and paste the link in the new
browser window and press enter.
Installation Instructions :
1. Download the SPXXXXX.EXE file to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions.
3. Restart the notebook when the installation is complete.
This should resolve the issue. If issue persists and you need further
assistance, please get back to us with SessionID: 10011011208244655996
I am sending the chat transcript to your email please check it and confirm
if you received it.
SOURCE: pc died suddenly. dies during reboots.
First step would be to remove the case and check all cables, ram chips and add-in cards (in slots on the main board): make sure everything is attached firmly.
Also check all your fans inside the case and the metal finned heatsincs undernieth them: they need to be operating when the computer is on and free from dirt & dustbunnies all the way into those metal crevaces: a can of canned air will blow the mess from the cracks. Make sure you follow the instructions on the canned air as tipping the can while using it can cause some damage, also make sure the computer is unplugged when you use it.
The symptoms you are describing could be the system overheating which would shut the computer off to save something from frying.
Over heating is the #1 cause of system crashes. please try these steps and post again here...
Regards..
SOURCE: Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
