How do i print from my galaxy tab 10.1 to my printer?
SOURCE: I just bought a lexmark pro205 printer and It will
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your Brother wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you.
SOURCE: Our Lexmark Prospect Pro205 has
Your cartridge may need to cleaned. On the printer operator panel, press Setup button -> Maintenance -> Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
If that doesn't help, your printer probably needs to be updated. The firmware update, available at http://bit.ly/p205fw, will help fix print quality issues.
SOURCE: when i connected the lexmark
This could be because of some blocked printer communications. Make sure to allow these communications in the program rules/permissions for your firewall. These articles should guide you on how to configure your firewall.
- Cannot Print or Scan from the All-In-One Center with Any All-in-One Inkjet Product; Firewalls Prevent Unknown Processes from Functioning
- Communication Failure When Trying to Scan, Print, or Perform a Smart Solution Function; Firewall Possibly Blocking a Process and Preventing Communication
SOURCE: How do I stop the
do the following o stop printing the Banner Page on a Lexmark Pro205 printer..........
Go to the following menu's in order as listed:
1.Network Menu
2.Standard Network
3.STD Net Setup
4.Network Card
5. Banner Page
And then select 'off' as the option.
SOURCE: cant print from android (samsung galaxy tab)
Lexmark
just recently released the Lexmark
Mobile Printing Application for use with Android devices, however, the
application is supported only on most laser products and the very latest inkjets that
are coming out for 2011(the Lexmark Pro715 and the Pro915 are the only
models announced at this point.).
Lexmark just recently released the Lexmark Mobile Printing Application for use with Android devices, however, the application is supported only on most laser products and the very latest inkjets that are coming out for 2011(the Lexmark Pro715 and the Pro915 are the only models announced at this point.).
