SOURCE: chipset driver needed where to get it or a site to download
You should be able to download this driver from your motherboard manufacturers website. Just click on the support link and lookup your specific board model #. Hope this helps.
SOURCE: How can i upgrade my intel(r) pentium r dual core 2.8 processor.
http://www.mercury-pc.com/p-mainboards-list.php hello, try this link to id the board, as you will see 5 945 mercury mainboards. if you pick the one you have, like 945gcm for example, you can find out the fsb, cpu, memory. if you still need help, reply please rate this solution and good luck!
SOURCE: Upgrade from pentium 915 D to dual core
The pentium d 915 is a dual core processor, albeit a bad one. You should check google for info on your motherboard to see if it supports Core 2 duo's/ Core 2 quads. I have an E6600 overclocked to 3.0ghz and it still plays games perfectly paired with my 8800gt 512mb and 4gb's ram. I definately recommend upgrading to a core 2 duo. I used to have a pentium d 915 and it was bad for gaming and the e6600 blows it out of the water. You most likely wont find the e6600 anywhere as it is nearly 3 years old. Look at sites such as toms hardware to find a good core 2 duo.
Good luck- an t-adh leat!
SOURCE: mother board software for Intel Core 2 Duo E4500
download ur board software from intel website..
good luck
shafky
SOURCE: how to overclock Intel Pentium Dual Core E2140
The following link will tell you the very simple way to overclock this processor. Half way down the page you will find the header "OVERCLOCKING"
http://www.value-reviews.com/index.php?page=pentium-dual-core-e2140
"Since the architecture was designed for the 1066 MHz FSB, overclocking
is as trivial as setting the FSB to 1066 MHz (266 MHz quad pumped).
...you instantly get a 2132 MHz CPU with little increase in temperature."
