Sony Cyber-Shot DSC-T33 Digital Camera Logo
Posted on Jan 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't take picture
ONE-Touch-Solution
Level 3:
  • Master 1,679 Answers
  • Posted on May 11, 2012
ONE-Touch-Solution
Master
Level 3:
Answers
1679
Questions
Helped
405041
Points
5442
May i know what exactly happens if you try to take picture ? Does the Camera load ( Power on ) and do you see the preview from lens ?
Anonymous
Level 2:
President:
  • Expert 261 Answers
  • Posted on Feb 16, 2012
Anonymous
Expert
Level 2:
President:
Answers
261
Questions
Helped
71685
Points
897
Hiif the key that you use for taking picture does not work in other parts need to change
Can't send or receive multi media text and picture text won't download when i get them
Contact your service provider and ask them to send settings to your phone. Its quick and free.
Jan 21, 2013 • Cell Phones
I put a sdcard in the mp3 player & it still won't hold a charge or save pictures that I take, why?
If you charge the MP3 player using the USB cable and the battery will not charge up then the battery is worn out and needs replacing.
Put in new starter in 2003 ford expodition and it still won't start what can my problem be won't even turn over?
Smart lock? do you have a picture of a red hand on instrument panel? With falcons quite common. Turn & hold key @ start posision, Hit dash upwards on left side of steering colum, If start = faulty smart lock module. I don't know if expodition has smart lock but probably does
The slide at the back of the phone won't let the camera work
Possible that the switch on micro switch which triggers from the slide cover is damaged and so does not switch on. You might need to remvoe to find this fault and replace the switch, set the alignment once again or refix the switch .
Shutter clicks ever time I press a button & it won't take pictures
I had this problem this afternoon, and it resolved itself when I took the memory card out. It's been fine so far, all working as normal again! :)
1helpful
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
I have an LG Venus 8800 in pink. When I recieve picture messages, it won't download them, and it won't let me send picture messages. Also, when I go to my Get It Now menu, I can select Music &...
hello kylie... begin by unplugging the phone from the charger if indeed it is plugged in. Then remove the battery and leave it without the battery for 2 full minutes. This action will cause it to reset itself. After you put the battery back in check it out for the misising functions. If there are still problems, take your phone to the phone store for their factory reset. Joe
We are having problems looking for the location of the shift solenoid on the 2002 ford explorer. could you email the picture or a diagram of the location of the shift solenoid
Put your trans model into your search engine
& find out where they are
May find a picture,may not
If you know nothing, there is plenty on all
transmissions made for fords for the last 70 years
YOU TUBE is always a good place to go
You can play with that & watch anything
I think you remove the pan to get to them
You don't go changing anything on a wish & hope,
push & poke theory
If you don't know what they do or how to test
them & you won't,go to a trans shop
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
