Facebook Social Network Logo
Posted on Jan 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My id is blocked - Facebook Social Network
BONG BRON
Level 2:
  • Expert 344 Answers
  • Posted on Jan 03, 2012
BONG BRON
Expert
Level 2:
Answers
344
Questions
0
Helped
116966
Points
867
Good Day!
If you can not access your Facebook account, go to
https://www.facebook.com/recover.php (click this link)
Provide your user id or email address. Then, follow the onscreen instruction and at the end it will reset your password.
To regain access to Facebook, try to look first at the inbox on your mail account, for the security code that Facebook sent to you. If security code is not in the inbox, search it at the spam folders.
And if your facebook account is blocked, please go to http://www.facebook.com/help/contact.php?show_form=disabled
(click this link)
fill up the form and click the Submit button.
or
You can write to [email protected], express your interest on recovering your account.
Explain why your account should not be disabled.
There are also helpful tips that you can find from this link:
http://facebookerrors.blogspot.com/2011/12/how-to-recover-facebook-account.html
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Need id block forever
someone else s id or your id ? in case it is someone else s you can block that person by going to their profile and blocking or you can go to your settings and choose to block them with their user name.
5helpful
3answers
59helpful
9answers
I want to block my facebook id forever
go log in to facebook and in the top right click the account tab > then privacy >scroll down to the bottom of the page and in the lower left by the bold "Apps and Websites" click the "edit your settings link > click the "edit settings" by apps you use. on this page you can remove access privileges anything that uses your facebook and apps you use while on facebook(including stubleupon)......if you want to hide your facebook to future sites you haven't visited in the past just make sure you are not logged into facebook when you enter a site and log out every time you're done using facebook
16helpful
5answers
How open my block id
my id is block i will open my id
57helpful
8answers
i want to block my id in facebook how can i
1helpful
4answers
21helpful
12answers
My yahoo id is blocked.how do i unblock it?
I am Unable to open my yahoo ID i cant try password reset because my alternet id has got blocked and secret question coming very different.. How can i open my yahoo id...your help needed.....
8helpful
9answers
My yahoo account has been block.
my id [email protected] this id is block plz open my id
Jan 20, 2009 • Yahoo Mail
Top Facebook Computers & Internet Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
